View Full Version : Looking for 70 amp relay with weatherproof base
mc1984ss
10-06-2018, 07:32 AM
Like the title says I am looking for a 70 amp relay for an electric fan. I can find 70 amp relays in some of the premade kits from Ron Francis, painless etc but none of them have a weatherproof base. I know I could run two smaller ones in parallel but this is not how I want to do it. Any help will be appreciated, thanks in advance!
andrewb70
10-06-2018, 09:09 AM
Tyco makes a 75 amp relay that is sealed and has big mounting lugs for the contacts. Installed properly it would be mostly weather proof (resistant).
https://www.waytekwire.com/item/75552/TE-Connectivity-V23232-A0001-X003-Power/
H2Ogbodies
11-29-2018, 01:24 PM
I have sealed 70a relays. PM me if you are still looking! It is a 4-pin.
mc1984ss
10-28-2019, 06:43 AM
Hey H20gbody,
I know this is a old thread but I'm hoping you get this. I'm finally ready to move forward on this project. Could you please send me the info on the relay you mentioned? What type and the price. Thanks!
CapSS92
10-29-2019, 06:10 PM
Here's a few to help you out while you are waiting. :)
https://www.waytekwire.com/item/46094/EATON-s-Bussmann-Series-Power-Relay-Module-70A-/
https://www.waytekwire.com/item/46095/EATON-s-Bussmann-Series-Power-Relay-Module-70A-/
https://www.amazon.com/dp/B07XC6KHD3/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07XC6KHD3&pd_rd_w=ryIYl&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=VplEM&pf_rd_r=5EM9S8HDBB7Y59DWMHK2&pd_rd_r=0f940432-716f-4daf-b06d-daff936e2777&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNTJOUzI5QThDOUsyJ mVuY3J5cHRlZElkPUEwNzI5MDI5Qk9FQVUyMVlGVlBXJmVuY3J 5cHRlZEFkSWQ9QTAyMjkwOTMyU08xRVg3UUdSQzdEJndpZGdld E5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmR vTm90TG9nQ2xpY2s9dHJ1ZQ==
https://www.amazon.com/Fastronix-Weatherproof-Automotive-Relay-Socket/dp/B01CXA42XK/ref=pd_sbs_263_img_2/147-8684018-1749750?_encoding=UTF8&pd_rd_i=B01CXA42XK&pd_rd_r=870b2d18-e90b-4b32-b691-d274fcf4ae10&pd_rd_w=1Ep6j&pd_rd_wg=Hp0dU&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=5EM9S8HDBB7Y59DWMHK2&psc=1&refRID=5EM9S8HDBB7Y59DWMHK2
anguilla1980
10-29-2019, 06:59 PM
I'm an electrical newb so forgive the question if it's stupid... but that seems like twice what a fan actually draws in amperage. Is that how you are supposed to size them? I ask because I'm questioning if mine are enough amps.
H2Ogbodies
10-29-2019, 09:36 PM
Rather than a big ole relay for the fan(s), why not set it up as a multi speed fan using a resistored relay kit? I build just such an animal for people who:
Dont care for aftermarket controllers with low amp capabilities,
And would like to use a mechanical tried and true HD relay setup.
Send me your info on what kind of fans, how you want them triggered and I can put something together for you!
mc1984ss
10-30-2019, 04:57 PM
Thanks for the reply, I am interested in what you mentioned and would like to learn more about what you suggested. Here is a link to the cooling components fan I'm planning on using.
https://www.speedwaymotors.com/Cooling-Components-CCI-1780-Cooling-Machine-Electric-Fan-Style-80,42296.html?gclid=Cj0KCQjw6eTtBRDdARIsANZWjYZsZO fK70i9X03glHlp087kIWAFfmylq6O09PjV_Hq9qIM7afDQaeMa AvtxEALw_wcB
My original thought was to just run it as a single speed fan for cost savings and simplicity. If I run it as a two speed fan do I need two separate temp senders in the radiator? I had previously sent you a PM, that can be ignored. Feel free to contact me through on and I can give you my email. Please let me know what options I have, thanks for the time.
To answer the other question above, the fan manufacturer says to use a 70 amp relay because it can draw up to 60 amps on startup
CapSS92
10-30-2019, 09:03 PM
Anguilla1980, people tend to use the bigger relays to cover the inrush current that the fans use when they turn on. I've used 40a relays and the only time I've had problems is when the wiring is not big enough to handle the current. Done right you should be ok. I wouldn't run two fans off one relay though. I go to the junkyards and pick up the relays including the connector for about $3 each all day long. If they're good enough to be used in a factory application they're good enough for me. :)
Alex
anguilla1980
10-30-2019, 09:10 PM
Alex
Sounds good. I have a 40amp relay for each fan with wiring even a gauge larger than is built into the relay.
Good idea on the junkyard relays!
OldTimer
11-03-2019, 12:39 PM
Cooling off performance cars reliably is probably more important than "What wheels are you running?" so I'm wondering if there should be a thread where folks list what's working for them? Vehicle/Engine/Fan(s)/Radiator/Controller plus a picture of the setup and your comments. Dumb idea or helpful?
CapSS92
11-03-2019, 12:58 PM
I agree. A database is always a good idea.
OldTimer
11-16-2019, 09:04 AM
How do we start a Database like this? Do we have to ask a moderator to start it, create a sticky, or what? What Fields would be important? Something like this?
Vehicle: List the vehicle.
Engine: List the engine.
Thermostat: List the temperature.
Radiator: Note here whether its an OEM/Aftermarket unit or repurposed one.
Radiator Type: Here's a spot to note whether its a 3-4 core, two/three/four tube, and tube size.
Fan(s): Single or Dual.
Fan Speed(s): Here's a spot to note if its a single or multiple speed fan.
Fan Temp Triggers: What temperature does the fan turn on and shut off.
Electrical: DIY or some aftermarket setup.
AC (Y/N): If AC, then whether fan is triggered by turning AC on.
EFI (Y/N): If EFI is controlling some aspect of the fan.
Comments: Here's a spot to note how this configuration is actually working.
Picture(s): Pictures are worth a thousand words, include a couple to show the fan/radiator and possibly the electrical stuff.
Please add/delete this could be a very helpful database, since almost all the vehicles here are "DIY" projects LOL.
Mike
Twentyover
11-16-2019, 01:37 PM
I have been known to use these for high current applications- Select continuous duty or intermittent as appropriate. It switches the entire vehicle power feed on the Camaro
http://www.texasindustrialelectric.com/relays.asp
