View Full Version : Detroit Speed 67-69 Camaro ProTouring Build Parts NEW IN BOX
Soarer
10-01-2018, 09:25 AM
Bought a ton of all the best DSE stuff to do an all out build on a 1969 Camaro but get caught up in two other projects and now a relocation for work so, my stockpile of parts is for sale. All this stuff is NEW IN BOX and never installed. The boxes were opened just to check out the parts and photograph. All parts are located in Danbury, CT 06810. I'm willing to ship the stuff that is manageable but not the big items. I have invoices for everything so I can prove what was paid and that all parts are legitimate. Package deals are available. Here's what's for sale.....
POWDERCOATED HYDROFORMED SUBFRAME - (1967-69 CAMARO / FIREBIRD / 1968-74 NOVA)
The Detroit Speed, Inc. Hydroformed Subframe Comes With The Following:
• Hydroformed Framerails
• Stamped Crossmembers
• Tubular Upper and Lower Control Arms
• DSE/JRI Coilover Shocks with 'Detroit Tuned' valving **UPGRADED DOUBLE ADJUSTABLE JRI SHOCKS
• Torrington Bearings
• Coilover Springs
• 'Detroit Tuned' Power Rack and Pinion Steering
• Splined Anti-Roll Bar
• Forged Detroit Speed Spindle
• Spanner Tool for easy shock adjustments
• Composite Anti-Roll bar bushings
Up to a 10" wide wheel can be packaged without modification to the inner wheel wells. Both the main and secondary crossmembers are stamped for structural rigidity. SBC, BBC, LS1, LS2, and LS7 engines have been designed as a direct bolt-in into this subframe.
Our subframe has been designed, engineered, and developed for the road and track. This subframe blends the benefits of current OEM technology and aftermarket performance into one product!
PAID $8,550
Asking $7,750
DSE Complete 9" Rear End Narrowed for DSE Mini-Tub Kit (QUADRA Link Assembled Housing W/Gears & Axles); Satin Black Finish - Specs to follow....
Paid $4,050
Asking $3,500
DSE Rear Suspension Kit (QUADRA Link 4-Link) W/O Axle Brackets - 1967-1969 Camaro/Firebird including QUADRA crossmember and track bar, QUADRA upper and lower links, JRI Rear coilover double adjustable shocks, coilover springs 8"x250 lb/in
Paid $3,250
Asking $2,750
DSE Front Runner Kit; Complete BBC Front Runner w/Power Steering: Black Hardcoat Finish
Paid $1,965
Asking $1,800
DSE Steering Shaft Kit + Components (polished stainless)
Paid $170
Asking $140
DSE Subframe Connectors: 1967-1969 Camaro/Firebird (2 Sets)
Paid $390
Asking $350
DSE Mini Tubs: 1967-1969 Camaro/Firebird (pair)
Paid $375
Asking $325
DSE Rear Tubular Anti-Roll Bar Kit (QUADRA Link - 1-1/8") 1967-1969 Camaro/Firebird
Paid $325
Asking $290
DSE Power Steering Pump (Aluminum) with integral reservoir
Paid $240
Asking $210
DSE Body Mount Kit (2 core support mounts + 4 body mounts)
Paid $140
Asking $110
DSE Body Mount Hardware Kits
Paid $99
Asking $85
Also have a GM ZZ572 (Street) 620HP Deluxe Crate Engine for sale in another thread. BRAND NEW NEVER RUN
NoSleeperII
10-01-2018, 03:52 PM
I am interested in the following:
Mini tubs
Subframe connectors (1set)
Body mount kit
Body mount hardware
Please pm me a price shipped to 77389
1Bad Ls
10-01-2018, 05:12 PM
Interested in the the body mount kit
bigalbert
10-07-2018, 01:46 PM
PM Sent
dmendez68
10-08-2018, 04:19 AM
What gear is in the 9", what is the width?
NoSleeperII
10-08-2018, 05:45 AM
I sent the above 6 days ago and have not received a response.
Soarer
10-08-2018, 05:53 AM
I’m still waiting to hear back from DSE on the specs.
NoSleeperII
10-08-2018, 08:22 AM
Soarer,
Are you not wanting to sell the above?
Soarer
10-08-2018, 08:25 AM
Just got the specs....
4.10 gears
TrueTrac diff
31 Spline Mosier Axles
54 3/4" width from flange to flange which is designed to work perfectly with mini tub kit
Torino end flanges
Quadralink brackets welded on
- - - Updated - - -
Does anyone know how to edit a post on this site? I need to update a few things on my original post in this thread. Does anyone know and admin that can help me with this?
Soarer
10-08-2018, 09:33 AM
I have sales pending on some stuff and want to edit some info on other stuff.
I'm trying to sell the big stuff locally because I don't want to deal with shipping on things that will have to go freight.
Dezz69
10-08-2018, 03:34 PM
I have the DSE REAREND housing brackets to complete the Quadra link kit if you sell the kit without the rearend
importkiller69ss
10-11-2018, 10:10 AM
Body mounts avail ?
Impala67
10-12-2018, 10:40 AM
Is the Front Runner kit still available?
1Bad Ls
10-13-2018, 01:32 PM
Interested in the the power steering pump. Do you know the spec and part number?
Soarer
10-16-2018, 12:24 PM
SALE PENDING ON: front subframe, rear axle, quadralink kit, steering shaft kit, rear sway bar kit, subframe connectors, mini tubs
- - - Updated - - -
Body mounts avail ?
Yes, mounts still available.
- - - Updated - - -
Front runner kit is sold.
- - - Updated - - -
The power steering pump is part number 090901
John McIntire
11-01-2018, 04:43 PM
Any updates? Did the rear and Quadralink sell?
1Bad Ls
11-04-2018, 03:37 PM
Pm sent
intimidator69
11-17-2018, 12:11 PM
interested in frt. and rear setup, 9" rear end, mini tubs , frame connectors have they been sold
Soarer
11-17-2018, 05:45 PM
The only things I have left are:
Zz572 big block
Hooker headers
PS pump
Bellhousing
Clutch
Pressure plate
Flywheel
This site is pretty ancient with its classified section. I wish I could go and edit my first post to update it for what’s available and what’s been sold but I can’t.
mtalp50
12-16-2018, 12:50 PM
hello , is the front subframe power coated and assembled ,And still availble? located in nj and would take the drive .Thankyou for your time
Soarer
12-19-2018, 08:46 AM
Please close this thread. I am going to list the remaining parts in a new thread as none of them are Detroit Speed and the title of this thread is now misleading.
badazz81z28
12-20-2018, 06:17 AM
Still have the DSE pump?
mtalp50
12-20-2018, 02:18 PM
is the subframe still for sale?
