dontlifttoshift
09-27-2018, 06:02 AM
Item Location (City/State):Beach Park IL
Price:$1650
Description: I upgraded the front of my 71 Camaro to Track 1 parts so I have my previous RideTech parts for sale. These parts have about 1700 miles on them, mostly driven on Sundays. :mock: Includes:
Lower control arms, delrin bushings
Upper Control arms with Delrin bushings and tall ball joints. I redrilled the bolt holes for the ball joints so I could get more caster and camber. Last alignment was 5 degrees of caster and 2.5* negative camber with zero toe. They can go back to the stock holes if you wanted a more normal alignment. You can still get the caster to 5 degrees but camber is limited to about 1* negative then.
CPP spindles with AC Delco C7 hubs.
Shocks are single adjustable but have the bitchin valving in them, drives nice at full soft but still mean enough to control the car while doing go fast things. Currently on 900# springs, can supply 700# if you just want to cruise.
ProForged outer tie rod ends with RideTech billet sleeves. One boot is cracked and would.
I will ship at your expense, probably 50-75 bucks to the lower 48.
https://static1.pt-content.com/images/pt/2018/09/ivnXt4gPXL-1.jpg
https://static1.pt-content.com/images/pt/2018/09/iQMr7TCVXL-1.jpg
https://static1.pt-content.com/images/pt/2018/09/idRfbQKkXL-1.jpg
Price:$1650
