BigblockBob
09-22-2018, 12:42 PM
Up for sale is an OBDII module from Dakota Digital. I originally purchased to use with my VHX gauges but I didn't use it. Unit is unused and in original box. Price is $85.00 plus the ride. See description below for more details.156801156802
OBD-II / CAN Interface
From Dakota Digital
https://static1.pt-content.com/images/pt/2018/09/prd_752-1.jpg?img_id=201712121634500
The BIM-01-2 OBD-II (J1850/CAN) Interface allows you to plug directly into the engine diagnostic port, extracting engine and transmission data from the vehicle's computer (ECM). The BIM-01-2 will collect and output the following information to Dakota Digital Instrument Systems *:
Always available:
Speed
Tachometer
Engine Temp
Check Engine Indicator
Vehicle specific:
Intake Air Temp
Transmission Temp
Ambient Air Temp
Gear Position
Oil Pressure
Boost
Please note: Due to the various factory and modified ECM's, additional data including (Intake Temp, Transmission Temp, Ambient Air Temp, Oil Pressure, and Gear Position) may be available, but will vary from application to application. Dakota Digital cannot guarantee the presence or accuracy of the Coolant Temp, Intake Temp, Transmission Temp, Ambient Air Temp, Oil Pressure, Boost or Gear Position displays since this is a function of the ECM and matching OEM functional sensors.
This product can provide a plus/minus 25 percent calibration to compensate for tire size or gear changes which have affected the speedometer output.
*The BIM-01-2 is designed to decode the information provided by the ECM through OBD-II and supply this information to the VFD3 rev. G, VHX and HDX control box instrument systems only. Earlier control boxes (with an aluminum case) are not compatible with the BIM family of Expansion Modules.
**The BIM-01-2 is designed for J1850 and CAN OBD protocols only. If you are concerned about compatibility with your vehicle please contact our sales or tech department.
***The BIM-01-2 is a direct replacement and upgrade to the BIM-01-1
From Dakota Digital
Always available:
Speed
Tachometer
Engine Temp
Vehicle specific:
Intake Air Temp
Transmission Temp
Ambient Air Temp
Gear Position
Oil Pressure
Boost
