View Full Version : 1969 Chevelle rim and brake combo
M.F.D.B.
09-19-2018, 02:47 PM
Ok, so I joined here after weeks of searching Google. I have a 69 Chevelle we are currently building an L-76 motor and will be running either an LSA blower or a Centrifugal. It currently is a stock disk brake car with rear drums and 15" rims all around. Looking at Wilwood options, they offer a 15" front rotor kit, but it requires a minimum 20" rim. Originally I liked the idea of 18s and 20s as I didn't think 20s on the front would clear without rubbing but I have not found a definitive answer. I want to keep the car around stock ride height. I could go 19s up front, but then I couldn't go 15" rotor. What do you guys think?
I hate rubber band looking tires so I want something around 50 series. I have 19x10s with 40 series on my Vette and HATE the ride!
So:
20x8 ish front and 20x10 rear?
19x8 ish front? Drop down to smaller front brakes?
Something else?
andrewb70
09-19-2018, 03:06 PM
If you hate rubber bands, then you don't want 20s. Also, why do you need 15" rotors?
Personally, I would go with 14" rotors in the front and run 18" wheels all around. Falken makes a 295/40-18 (27" tall) that will fit in the rear and on the front you can run 255/40-18s (26" tall). It is a great combination that will look great and have good handling, presuming you have updates suspension.
Yanchik
09-19-2018, 03:31 PM
@andrewb70
Not trying to bash, but wouldn’t a square setup provide best handling?
raustinss
09-19-2018, 05:36 PM
No not necessarily... the weight bias of the car will play into that thought process
andrewb70
09-19-2018, 05:47 PM
@andrewb70
It depends how the car is set up. Then again there are aesthetics to consider. A small stagger in width does look good on an A-body.
M.F.D.B.
09-19-2018, 10:27 PM
I drive a 69 Chevelle, "need" has little to do with anything, lol.
What's the difference between a 40 series on an 18 vs a 20? My current 19s have 40 series tires. While I wouldn't call them rubber bands, a slightly larger side wall would be nice.
My wife and I both love the look of tucking rim in the rear. Since I don't want to lower the car, bigger rims are the only option.
andrewb70
09-20-2018, 04:17 AM
The difference is overall tire diameter. It's a Chevelle, not a dump truck. In terms of aesthetics, I think a 27" tall tire in the rear and a 26" tall tire in the front is perfect. Now go look at various tire sizes for 20" wheels and see what kind of overall tire diameter you're working with.
M.F.D.B.
10-01-2018, 08:12 PM
Will a 20x10 with 5.5 back spacing fit out back, without rolling/trimming?
Are there any issues up front running a 20x8.5?
USAZR1
10-02-2018, 04:15 PM
Yes, unless the rear quarters were replaced and poorly fitted. Then, you "might" have to mildly roll the fender lips. My suggestion would be 20x10's w/5.75" backspacing (+6 offset), if possible. I'm running that wheel spec, with 305/30/20 Nitto 555 G2's on the rear of my 70 Elco, with 2" drop. No fenders mods have been required.
https://static1.pt-content.com/images/pt/2018/06/IMG_0345_750x325-1.jpg
M.F.D.B.
10-03-2018, 12:23 PM
Are Elco rear fenders the same as a Chevelle?
I certainly dont want to go as tiny as a 30 series but the fact you have a 2" means I should have similar clearance with stock height and a bigger sidewall.
The rims I want are the same as you have now (and my car currently has, but in 15"). The difference is the spokes are black and the lip is a deep dish bare machined (about 4" lip). The only problem is since they are discontinued, im stuck with the 5.5" back spacing of the remaining inventory. I have looked all over and have not found an alternative. =(
USAZR1
10-03-2018, 08:27 PM
Yes, wheelwells are pretty much the same dimensions. As others have mentioned already, if you have to have a tall sidewall, you're wasting your time looking at 20's. My 305/30/20's are 27.2" tall which equals a 3.6" sidewall. Even a 5" sidewall on a 20" wheel would equate to a 30" tall tire. That's getting really close to a max-height tire, for an A-body.
A 10" width wheel with zero or positive offset will not have a deep dish. Deep dish wheels are almost always negative offset and these cars do not like those, especially if wider than a 7" width.
mc84_zz4
10-04-2018, 03:01 PM
Here is one thread you can dig into, I love the stance and wide footprint.
https://www.pro-touring.com/threads/54033-Introducing-my-69-Chevelle?highlight=
mc84_zz4
10-04-2018, 04:09 PM
Sorry, I timed-out before finishing....
Wheel/tire specs: 275/35/18 front, 315/30/18 rear.
On Forgeline 18x9.5 (5.5 bs) 18x11 (6.5 bs) Stock frame, no tubbing in the rear
M.F.D.B.
10-04-2018, 10:19 PM
The, "deep dish" on the Torque Thrust style wheel comes from the curvature of the spokes. I'll attach a couple pics of what I'm looking to do.
- - - Updated - - -
Bitchin!
Shawn0331
10-05-2018, 03:42 AM
To be honest you might be able to clear the 15'' rotors with a 19'' wheel. i have the 14'' wilwood aero setup and i have tons of room with a 18'' wheel. Obviously each wheel is different but i think it would work.
M.F.D.B.
10-06-2018, 10:11 AM
You are right, I double checked and the minimum is a 19. But I'm not sure it would be better in regards to tire choices tho?
USAZR1
10-06-2018, 04:30 PM
Why is that? What tire width do you want to run?
Either a 265, 275, or 285, in a 30 or 35 aspect ratio, would work well, in a 19.
Billet-Specialties
10-08-2018, 01:06 PM
Here is an example of Billet Specialties Legends Series Speedway Wheel on Chevelle 20X8.5 and 20X10
157292
For more information click here (http://http://bit.ly/2ho1cQA)
M.F.D.B.
10-08-2018, 10:12 PM
157292
That thing looks bitchin! It's lower than I'd go with these terrible streets here in Vegas. What's the specs on the back spacing and tires? Any fender mods?
67King
10-09-2018, 03:41 AM
@andrewb70
Not at all, you want to fit as much tire as you can, and adjust spring rates, accordingly. On my track car (Porsche 944), I had been running square to try to extend tire life to a staggered setup as I got faster and stuff. Rear spring rates went from 550 to 850 when I did that, didn't miss a beat (well, it absolutely did when I tried driving it the first time just by adjusting the way bars - once I got the right springs on there, it was fantastic). Most of the race cars we run are 245 front, 285 rear.
