View Full Version : 69 Camaro Suspension and miscellaneous parts
Carbo
09-16-2018, 07:59 PM
Cleaning out the garage and have a lot of useful parts leftover from the build.
LCA'S with poly bushings - $100.00 shipped
Superior Aluminum Radiator with steam port and thermal switch port installed. This radiator can be used with a SBC/BBC or an LS engine - $160 shipped
Stock gas tank with sending unit. Tank has sump installed with an fitting for a return line on the front of it. I also have a whole drilled in the filler neck to attach a barb style fitting and hose for extra breathing. I ran an electric pump but this tank is still capable of using the stock set up. $150.00 shipped
Window Regulators for all four windows - perfect working order - $100.00 shipped
OEM Red dash pad - $175.00 shipped
Axle stops - $20.00 shipped
Steering arms - $40.00 shipped
Spindles - $75.00 shipped
Complete tie rod ends, only used for mock up - $25.00 shipped
Polyurethane engine mounts - $20 shipped
Engine frame mounts - $20.00 shipped
New Engine frame mount - LH side, some paint removed over bolt holes - $10.00 shipped
Crane cams Vacuum canister - $25.00 shipped
See photos here: https://www.flickr.com/photos/142475677@N07/
Carbo
09-17-2018, 08:17 PM
Axle stops, Engine frame mounts and Steering arms are sold.
importkiller69ss
09-19-2018, 08:55 AM
What brand are the tie rod ends
Carbo
09-19-2018, 10:54 AM
They are Moog.
importkiller69ss
09-19-2018, 01:49 PM
I’ll take them
Carbo
09-19-2018, 04:04 PM
PM sent
Carbo
09-20-2018, 01:57 PM
Tie Rods sold. Thanks Bryan.
Carbo
10-06-2018, 11:20 AM
All parts are negotiable. No reasonable offers will be refused. Really like to move this stuff.
