View Full Version : Your thoughts on wheel spacers/adapters
Slick68
09-14-2018, 01:50 PM
If I want to buy some wheels with a different lug pattern, would I be ok to run some spacers/adapters while autocrossing? Would the stress be too much? for the spacers to handle?
Zspoiler
09-14-2018, 02:21 PM
Thats an awful strain in you lug nuts,Plus the offset maybe wrong with the adapters.
ULTM8Z
09-14-2018, 03:06 PM
I"ve been running the same adapters (not spacers!) since 1998 when I put on my C4 Vette wheels. Haven't raced with them, but I haven't been gentle either. Never had one iota of trouble with them.
Again, these are not spacers. They bolt to the wheel hub like a wheel. They then present a separate set of lugs to the wheel itself. 6061-T6 aluminum... they're very strong and I seriously doubt you'd be able to break them.
mitch_04
09-15-2018, 05:33 AM
I heard an interesting concept once.... a brake rotor is basically a small wheel spacer!
Mr Nick
09-15-2018, 06:47 AM
A high quality bolt on spacer/adapter is nothing to worry about.
It's the excessively thick slip on spacers that cause problems. I have no testing data to back this up, but I personally would not feel comfortable with a slip on spacer more than 3/8" thick.
csouth
09-15-2018, 06:54 AM
Look at motorsport-tech.com. They make hubcentric wheel adapters.
Slick68
09-16-2018, 04:55 PM
I should've included a bit more info. I would need a 1.25" spacer and adapting to a different lug pattern, so the bolt on style is the only option. That being said, you guys answered my question about them being ok as long as I buy quality adapters(which I would have anyway.)
I have ran 7/16" slide on spacers before with the extended shank lug nuts. They never gave me issues, but I checked torque on them every time I drove it just for added peace of mind.
csouth
09-16-2018, 05:04 PM
I should've included a bit more info. I would need a 1.25" spacer and adapting to a different lug pattern, so the bolt on style is the only option. That being said, you guys answered my question about them being ok as long as I buy quality adapters(which I would have anyway.) I have ran 7/16" slide on spacers before with the extended shank lug nuts. They never gave me issues, but I checked torque on them every time I drove it just for added peace of mind.
I think we understood. The address to provided is a company the makes hub centric wheel adapter spacers. They will convert the lug pattern and they are a tight fit to your center hub on the axle or front wheel hub... Only company i would use.
CSG
09-17-2018, 05:28 AM
I run a 1.5" adapter on my jeep and have for over 6 years. 40" tires and nitrous in a rock rig. Have not had any issues with these.
chuckd71
09-17-2018, 02:44 PM
Just checked their site out and went through a mock purchase; very nice interface and definitely who I'll use when I order my adapters
GoodysGotaCuda
09-17-2018, 03:07 PM
I ran 1.5" lug centric spacers with 140lb wheel assemblies [yes, 140lbs per wheel] on very demanding rock crawling situations for 75k miles. I have no worries running spacers..
156618
