View Full Version : DSE rear drop springs
2fast4u
12-05-2005, 02:43 PM
Just got my DSE drop springs in with 3" drop. I noticed only one side has rubber bushings pressed in. Any reason why the other side doesnt have any pressed in???
Which way does the spring face...does the side where the rubber bushings are currently installed face toward the front of the car???
Lastly do you recommend complete poly bushings in the rear springs and delalum bushings for the stock front control arms??? Street/strip use.
JLM
12-06-2005, 07:39 AM
The front of the spring is the portion with the installed rubber pushing. That installs on to the frame. You'll then have the shackles that attach the spring to the aft portion of frame rail.
