View Full Version : C6 Z06 Caliper bleeder repair
csouth
09-09-2018, 09:05 PM
I was disassembling my calipers for powder coating and and found that the threads on one of my bleeder holes is stripped. Can anyone recommend a reliable repair method or someone that fixes this? Would like to get is done before PC in case its intrusive.
Thanks156345
Bad Bowtie
09-10-2018, 12:40 AM
Chris,
I did a quick Google search and found a couple of viable options in repair kits, you should be able to get them at a local parts store. Not sure exactly on your caliper size bleeder but I seen they offer some for motorcycles too which are fairly small if you needed a small one.
Good luck
BB
csouth
09-10-2018, 09:27 AM
Chris,
Good luck
BB
Thanks, I found a couple of options after I posted this last night. I'm going to hit the auto parts store today. I want to have this resolve so I can drop the calipers this week.
badazz81z28
09-11-2018, 03:04 AM
Personally, I would hit up autozone for new caliper instead.
csouth
09-11-2018, 09:48 AM
I’m going to helicoil it. It ordered a kit last night.
raustinss
09-11-2018, 02:36 PM
Yes a properly installed heli coil or drill and tap to a larger bleeder size should do the job for you, worse case you will need to buy a new caliper .
badazz81z28
09-11-2018, 07:13 PM
Personally I don’t see fixing it is as cost effective nor for someone like me....it will always bug me the caliper isn’t perfect and has a different size bleeder in it. Especially if I was investing money into them such as PC.
They are not expensive at the Zone.
csouth
09-11-2018, 07:51 PM
Personally I don’t see fixing it is as cost effective nor for someone like me....it will always bug me the caliper isn’t perfect and has a different size bleeder in it. Especially if I was investing money into them such as PC. They are not expensive at the Zone.The bleeder will be the same size with the Heli Coil and AZ doesn't carry the z06 calipers as listed. The calipers they sell are the J55 pkg, the z06 is j56. I had looked there before I thought of repairing.
icemanrd19
09-11-2018, 08:01 PM
i would go to the auto parts store and see if there a next size up bleeder screw and tap it
icemanrd19
09-11-2018, 08:08 PM
7/16 is alittle bigger than 10mm right?
https://www.summitracing.com/parts/agb-s11410
raustinss
09-12-2018, 08:20 AM
Yes ... 10 mm is a sliver larger than 3/8 ... btw to convert take the measurement and multiply or divide by 25.4 .... .375x25.4 =9.525 mm
JEFFTATE
09-12-2018, 02:05 PM
Make sure not to drill and tap too deep. Remember, the bottom of the cavity is tapered so the bleeder screw ( which is also tapered ) will seal. Don't drill it till its flat .
csouth
09-12-2018, 04:11 PM
I plan on marking the drill bit and the tap so I know exactly how deep I'm going in during the process. I'll take my time in the best effort not to ruin the caliper.
Skip Fix
09-17-2018, 01:06 PM
Worse case you can tap for NPT and use a Wilwood bleeder as it has both pieces.
csouth
09-17-2018, 02:51 PM
I popped a heli coil in over the weekend, calipers are at the coater now.
