View Full Version : wich one is high pressure
copo69
09-21-2004, 09:48 AM
:camaro: wich power steering line hole is high pressure upper left one or lower right one? thanks
harshman
09-21-2004, 10:13 AM
it is the hose that has the hydraulic crimp on fitting. if you have the resivor type pump, it should be the hole towards the driver's side. the gear box, the lower one.
copo69
09-21-2004, 05:21 PM
i know wich hose is high pressure i was wondering wich hole is the high pressure one.. one hole sits low one sits high . wich one is high pressure low hole or high one . :bananna2: thanks
chevymike
09-22-2004, 06:10 AM
On mine, which I hooked up a few weeks ago, the one near the engine was the high pressure and the one near the wheelwell was the low pressure. On my AGR box, the high pressure one had a slightly bigger fitting so you could not mix them up. Hope that helps.
