View Full Version : 1969 Nova with SPC control arms alignment specs for steet use please
Moabdude
09-05-2018, 11:27 PM
Hi,
I have a 1969 Nova with SPC adjustable upper control arms.
I will mainly use the car on the street and not on the track.
What are the best settings for caster, camber and toe-in?
Pinion angle
Also I have a Ridetech 4 link in the back with shockwaves.
The transmission sits on a 4 degree down and the rear axle on a 4 degree up. Is are these angles ok?
Thanks for your help!
Bram
btmatt
09-06-2018, 08:16 AM
here are the specs i received from SC&C for my camaro
Street Comp-AFX Alignment Specs
*Street/Show*
Camber: 0 to -1/4 degrees
Caster: +4 to +4.5 degrees
Toe in: 1/8" total
*Street Performance*
Camber: -1/2 degrees
Caster: +5 to +5.5 degrees
Toe in: 1/16" total
*Mild Competition* NOT Recommended For Street Use
Camber: -1 to -1.5 degrees
Caster: +5 to +6 degrees
Toe: 0" to 1/16" toe out (autocross)
Moabdude
09-07-2018, 11:07 AM
Thanks for the specs. i will do the alignment next week.
