View Full Version : LS2 swap fusible link
AU Doc
09-03-2018, 04:22 PM
I need a fusible link for my ls2 alternator. I think the fusible link should be a #8, but it haven’t had any luck finding a link that large. Can anyone point me in the right direction?
badazz81z28
09-03-2018, 05:46 PM
Fusible link? Thought of midi fuse...Does the factory even use fusible links anymore?
Fusible links were for low amp alternators in older cars. Your power demand is too high for small gauge wires. My factory wire coming off the alternator was like 10-12g. Now with the LS the wire is 4ga. Considerably thicker.
badazz81z28
09-03-2018, 06:08 PM
Something like this. They provide one with their wiring kit
https://www.painlessperformance.com/wc/80000
dhutton
09-03-2018, 06:15 PM
American Autowire classic update kit comes with an alternator fusible link. You can probably get one from them.
Don
AU Doc
09-04-2018, 05:06 AM
I was a little surprised to find a fusible link, myself.
I may have to use a fuse, but it will need to be somewhere around 200 A, I believe. I'm not as familiar with automotive wiring, but I think the guidance is somewhere between 135% and 300% of device rating. Typically you size the protective device for the conductor, but I've yet to find a solid reference for automotive wire ampacity.
I suppose worst case I can splice this one back into the wire I have, and hope it never fails :)
156211
badazz81z28
09-04-2018, 07:51 AM
Don
Is it for a high amp alternator or stock?
dhutton
09-04-2018, 08:24 AM
No idea but I assume higher than stock for a classic update kit. I have used it in several LS builds without issue....
Don
dhutton
09-04-2018, 08:28 AM
156211
If you use a fuse I think you will also have to derate it for the high under hood ambient temperature.
Don
AU Doc
09-04-2018, 11:29 AM
I emailed American Autowire, and they don't offer a primary lead that size. They pointed me to Powermaster, but they don't use fusible links in their alternator primary leads. The tech I spoke with at Powermaster said they don't see fusible links used anymore and suggested a fuse may be the way to go.
badazz81z28
09-04-2018, 10:45 PM
^^ yup. So does painless. If I was home I would get the amp rating for you.
