View Full Version : Budget Subframe
Joey52
09-01-2018, 04:53 PM
Hello all, I have a question on my 69 camaro subframe. My car needs to be restored some. I'm having it repainted and the firewall smoothed. to redo my current factory frame is gonna be pricey to fix to my taste . My question is are there some relatively budget friendly options to the factory frame or am I better off keeping the factory and add some good bolt on options. I can see it costing me easy 2-3K to freshen up the factory one and prob not add alot of performance unless i add $. Any suggestions from you guys on a good complete subframe ?
156133
TheJDMan
09-01-2018, 06:32 PM
Have the stock sub-frame seams welded up and then install a ridetech Street Grip kit
I pretty sure there aren't any budget aftermarket sub-frames in the 3000 dollar range I have seen a few drag racing ones but for touring cars the gear needs to be a little beefier, most are R&P and require the linkage for that and sometimes even different steering columns along with custom fit headers
Joey52
09-02-2018, 04:00 AM
that kit looks pretty nice, thanks for the reply.
Joey52
09-02-2018, 04:06 AM
That kit looks nice and not unreasonable for a front and rear. thanks for the info. I have a ton of work to do and a unexpected paint job is cutting deep into my budget . 6K-8K unexpected over crappy prep work in 91. i was hoping for full frame upgrade but that little expense knocked that out right out of the gate .
Joey52
09-02-2018, 04:17 AM
Yes sir , I don't plan on any fancy racetrack time, i just want to have a good handling cruiser that is reliable and i can blast on long roadtrips without worry. so a upgraded fast ratio steering box will be fine for me. i don't need R&P really , although i'm sure its nice, defiantly not needed. Going behind bad work has turned out to be costley but i can make it right just have to pick my battles on the things i want vs what I actually need.
