View Full Version : WTB all good parts for camaro 67
lolo3198
08-27-2018, 05:03 AM
Hello
I want to upgrade my camaro 67 and i search a lots of parts (brakes kit, 4link, coillover...)
Camarofreak67
01-05-2019, 10:12 PM
I have a full TCI chassis that I am trying to get rid of I am wanting to go full frame it’s a stage 3 from TCI Corey 5094991862
Motor
01-06-2019, 07:14 AM
I have a tremec 6speed trans with shifter and QuickTime blowproof bellhousing as well as the hydraulic throw out bearing. Call me at 6147838380.
Timmah
01-06-2019, 08:45 AM
Hi,
I have all the parts from DSE to update the stock frame for a 1969 nova which is the same as the first gen Camaro's (coil over, upper lower control arms, sway bar, tie rod sleves ect). I also have the power steering box rebuild and tune by DSE. I have the ATS stock height spindles, one set OEM spindle, one set of DSE spindles. I have a stock frame with the DSE kit to upgrade to coil over that is already converted. lots other items as well. too many to list. I turn direction on the project and have not taken the time to list to sale.
Where are you located? I would be glad to talk with you if you want to PM.
Thanks Tim
DonohurJav
01-10-2019, 02:35 PM
I have a stainless steel gas tank with a new aeromotive phantom fuel pump installed, and all the braided lines and fittings if you are interested. It's a 68 tank. Aren't the 67 & 68 the same with short snout and the 69 has the long filler?
Sean
TANKMASTERJ
02-02-2019, 05:59 PM
I have a factory 67 Camaro subframe. MBM tubular control arms
All new steering linkage. AGR fast ratio steering box new in the box.
new rag joint. Has 11" wilwood discs with wilwood calipers. Has the power booster also wilwood. The shocks are brand new Viking double adjustaes. And got a chrome steering column for it. New in box.
Asking 3000.00 for all. pm TANKMASTERJ or email [email protected] if interested. All on subframe bas less than 3000 miles. Went to a Speedtech subframe.
