View Full Version : What Are These Ports for LSA??
joeko23
07-26-2018, 04:33 AM
I have a pullout ZL1 LSA and can’t figure out what these ports are for and what I should do with them. Any help is greatly appreciated!!
nicks67camaro
07-26-2018, 06:01 AM
the second one is the evap system port PSI harness eliminates it. from their instructions:
3. LSA engines utilized Evaporative and CCP features for emissions control. This
harness does not include these provisions. Evaporative and CCP are not necessary
for engine operation. ECM reprogramming may be necessary to avoid storing a
Diagnostic Trouble Code (DTC) for absence of emissions equipment.
First one is believe is another vacuum port which can be capped
joeko23
07-26-2018, 07:01 AM
So both ports can be capped? What should I cap them with? A link would be great. Want to use the right cap for the job
dhutton
07-26-2018, 07:34 AM
I bought an evap solenoid cover on eBay. A regular plastic vacuum cap will work fine on the other. Do you have power brakes?
I think this is it:
https://www.ebay.com/itm/LS-Truck-EVAP-Purge-Solenoid-Tube-Plug-Intake-Block-Off-EVAP-Delete-5-3-6-0/201626142381?hash=item2ef1dac6ad%3Ag%3AvswAAOSw4-hZrdz6%3Asc%3AShippingMethodStandard%2176233%21US% 21-1&_sacat=0&_nkw=ls+evap+solenoid+cover&_from=R40&rt=nc&_trksid=m570.l1313
Don
nicks67camaro
07-26-2018, 07:36 AM
for the evap
https://www.ebay.com/itm/LSA-Supercharger-Vacuum-Port-Block-Off-Plate-Plugs-LSA-Vacuum-Port-Delete-/192114644370
you can use a simple vacuum cap on the nipple style
https://www.ebay.com/i/132550653135?chn=ps
joeko23
07-26-2018, 08:21 AM
Thanks for the links guys. Yes I will have power brakes using vacuum which is a different port that I figured out.
