View Full Version : Stealth Engine Bay Heat Venting
MAGONSTERZ68
07-16-2018, 09:24 PM
has anyone had success venting heat through rear inner fender wells?
i don't want to cut up my hood or outer fenders.
as i understand it heat currently vents through the side lower ports of the fenders just front of the firewall.
i wonder if cutting a section out in this same area and bending into flap to capture incoming radiator air flow and direct into outer fender well would assist without creating odd aero lift or push at higher speeds.
Tweak
07-16-2018, 09:32 PM
Hey
What about venting at top of fire wall out through cowl?
Just a thought as hot air always wants to rise
Cheers
MAGONSTERZ68
07-16-2018, 10:27 PM
i think that would work for low speed and stop and go traffic but if not mistaken the high pressure at base of windshield would prevent any real evacuation at cowl and may even intake fresh air when it exceeds pressure of the engine bay, suppose could induce fresh air at high speed.
Tweak
07-16-2018, 10:54 PM
You make a good point. I want to 3D scan my car and get into aero design.
Chad-1stGen
07-18-2018, 04:57 PM
I would test the pressure differential in the spot you are considering before doing any cutting. If you have good pressure differential it would work. If you don't then it's a mistake. I used a magnehelic gauge to do that for my hood vent placement.
MAGONSTERZ68
07-18-2018, 05:24 PM
have any pics of finished product?
thx
Chad-1stGen
07-19-2018, 09:21 AM
thx
Finished pics of the hood vent install are here (https://www.autoxandtrack.com/trackspec-motorsports-1967-1969-camaro-hood-louvers-install/).
If you are asking about using the magnehelic gauage to determine placement then check out the post I made here: https://www.pro-touring.com/threads/82119-Chad-s-68-Camaro-V3-0-begins/page9?p=1147911#post1147911
JustJohn
07-19-2018, 09:35 AM
What kind of car? If it has astro ventilation you might be able to take advantage of some of the existing ducting. It routes both inside and at the outer bottoms of the fender wells.
MAGONSTERZ68
07-19-2018, 06:59 PM
vents look great and seem to function well.
- - - Updated - - -
68 camaro convertible, asto has been eliminated due to vintage air install
JustJohn
07-20-2018, 05:54 AM
- - - Updated - - -
Mine are too but I used the kick panel openings for speakers and fabricated a blank off plate at the cowl to keep from building pressure behind them. If you left the cowl grill in place then you likely still have a significant pressure differential between there and the lower drain holes. Since it is that way by design, you may be able to take advantage of it.
