View Full Version : Front upper control arms
1985olds
07-09-2018, 07:34 PM
This may sound like a dumb question, but Do the more expensive front upper control arms make that big of a difference on a mainly street driven car? Currently I have cheapie South side machine uppers on my car. I have a set of new umi uppers on my self and am wondering if they are worth swapping them in? The link below are the umis that I have.
http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_59_273&products_id=610
csouth
07-09-2018, 08:20 PM
I don't think it's the price, but the R&D UMI has put in developing the parts that make them worth it. If you chose UMI, you've probably seen the test vehicles and know the Green Machine performs. I don't know anything about SSM, but the test vehicles of UMI show how they can back their product up with real life performance.
79T/Aman
07-10-2018, 07:55 AM
there is no difference in how a control arm looks, all they do is connect point "A" to point "B" ( in this case ball joint to bushing ), there are however differences in the relationship of point A and B that can be altered to improve caster setting, ball joint angle, the type of bushings used, offset cross shaft.
The only issue with the SSM is that from the set I saw they were straight off the circle track parts shelf, they will work, the solid bushings are great, no deflection and last a life time, make sure you grease them, the negatives are no droop stop, (not a big deal), unsure as to the amount of positive caster that may be built in, lack of offset in the cross shaft ( not a big deal ) the biggest problem with circle track upper arms is that they are sacrificial parts, they are made to bend when a race car tags the wall or another car to save the rest of the suspension and frame from getting damaged so they are made of thinner wall tubing.
