View Full Version : Why does this forum destry post fomatting?
a67
07-05-2018, 05:30 PM
Check this post: https://www.pro-touring.com/threads/128749-Procedure-For-Shimming-Control-Arms-To-Add-Camber?p=1270596#post1270596 It was nicely formatted with sentence breaks and paragraphs. But now has all sentences run together. WHY? Bob. P.S. I'll bet this post does the same. As posted there are sentences that are blank line separated... - - - Updated - - - Yep, all sentences in this post run together... Bob.
Larry Callahan
07-05-2018, 07:51 PM
This is something that I have not seen before.
Are you writing your posts is something like word and then pasting it here?
CarlC
07-05-2018, 10:26 PM
This can happen if trying to copy/paste the text used in another forum as well. Ask me how I know.... ;-)
a67
07-06-2018, 05:16 AM
The post(s) were typed in via the reply dialog, native to the Pro Touring forum.
Bob.
csouth
07-06-2018, 06:10 AM
Bob.
What browser are you using? It would seem its something user specific based on the fact other posts before and after yours in the same thread had the lines spaced out.
a67
07-23-2018, 01:27 PM
What browser are you using? It would seem its something user specific based on the fact other posts before and after yours in the same thread had the lines spaced out. Firefox V 52.8.1 Just occurred again: https://www.pro-touring.com/threads/128192-Timing-control-yes-no?p=1271977#post1271977 That post was opened/entered via a simple reply. The post after that one did the same with a quote (deleted the quoted text), didn't want to actually quote. Just wanted to see if it made a difference. Bob. P.S. just to add this post also has the white-space formatting removed. P.P.S. I am also active on other forums and this issue has not occurred.
a67
07-25-2018, 10:13 AM
Testing
Testing
Bob.
a67
07-25-2018, 10:15 AM
Testing1
Testing2
Bob.
a67
07-25-2018, 10:16 AM
Testing3
Testing 4
Bob.
csouth
07-25-2018, 10:26 AM
If your Firefox is 64bit, you're waaaaaay behind.
I'm posting this with Firefox and the version 61.0.1
I purposely spaced this out.....
a67
07-27-2018, 02:31 AM
It is 32 bit and from the ESR channel. No beta testing for me. I have an idea of what is causing the issue, as you can see above those posts formatted correctly.
Bob.
Larry Callahan
07-27-2018, 05:33 PM
Any thoughts? We have been working on the server in the background and wonder if any changes we made had any effect.
a67
07-31-2018, 08:49 AM
A while ago I started running the NoScript add on. Was thinking that it may have been a blocked script that wasn't allowing the proper formatting. But the above tests showed that it may not be that.
If this post formats properly then it wasn't that (note this line is a new paragraph with a blank line between it and the previous paragraph).
Bob.
{edit to add: the formatting is correct}
{second edit: after adding the edit line the post is now all run together, so something is still wrong}
a67
08-04-2018, 08:22 AM
OK, so unless a board change was made it was me. I just made a few posts including editing the above post. And they formatted properly.
I was only allowing the main board (pro-touring.com) script to run but not the others. So apparently one of the other three scripts was required.
Bob.
Larry Callahan
08-06-2018, 08:44 AM
Nothing we changed should have had any effect. I'm glad to hear that it's working for you now.
a67
08-06-2018, 01:50 PM
Thanks, I enabled the jquery and the pt-content scripts. That does the trick.
I don't like having to run NoScript, but it has gotten to the point on many websites they create dozens of connections to other sites. Talk about using bandwidth and memory, to the point that the PC just slogs down. I've even gone as far to adjust my purchases so I don't have to deal with those sites.
Bob.
Larry Callahan
08-08-2018, 06:43 PM
Bob.
Sorry for the trouble. I try to keep everything as close as possible. The goal of the site is to survive and not make a living off it. I have a day job for that. LOL!
