View Full Version : Question on Jeep steering box on '68 Camaro.
minendrews68
07-05-2018, 07:24 AM
When using the Jeep steering box on a '68 Camaro, is this a direct bolt in or does a adapter have to be made? What are the advantages of using the Jeep box?
rixtrix1
07-05-2018, 11:44 AM
It should be a bolt-in, but you need to get a 93-97 Grand Cherokee box and adapters for metric hoses(O-ring vs flare) and the correct coupler( rag joint). The benefit is a faster ratio (12.7-1) and less turns lock to lock. You'll need a power steering pitman arm and possibly a power steering draglink if replacing a manual box. Tons of articles, just Google it for more info. I have one on my 1966 Malibu and it's sweet.
lobudget
07-05-2018, 01:07 PM
IIRC the Jeep box has a greater range of motion that the Gen 1 F body (which is why it works well in Chevelles) so it might allow tires to kiss the frame before full lock but that is probably something a driver could anticipate and avoid.
79T/Aman
07-05-2018, 03:13 PM
even if the steering box had greater turning angle the spindles have physical steering stops so nothing would change, if you need something cheap you also can use a 3rd gen f-body box, z28-T/A they are 12.7 : 1 but the reality is there is nothing like a new 600 series box.
minendrews68
07-06-2018, 08:50 AM
Thanks guys for the information.
