View Full Version : Ls1 rear brake swap
importkiller69ss
06-21-2018, 01:04 PM
Just started back on my car after it sitting for 9 years.. swapping ls1 rear brakes on my 69 camaro. So far I have 2 lh backing plates. Calipers rotors the wheel studs ext . Question is about the lines. I don’t have the factory lines from the donor caliper So I’ll need those .. my car has drums now so what do I need to connect the lines from the calipers to the hardline on my axle
importkiller69ss
06-21-2018, 01:13 PM
And since I am using 2 lh backing plates do I need 2 lh calipers
Randy67
06-25-2018, 06:12 AM
Kore3 has brake lines that will the stock hard lines and have the right connection at the caliper, I used them on the El Camino I had. No adapters needed.
I do believe you need 2 LH calipers.
Josue
06-25-2018, 12:30 PM
^This.....
I believe the pics in my build thread are working again (stupid photobucket), and I did the same swap. Check out the link in my sig....post #24
