View Full Version : Adjustable Prop valve with cpp prop valve
chevelletiger
06-06-2018, 05:27 AM
Hi all,I'm in the process of installing my wilwood manual mc.
On my 72 chevelle,c5 vette brakes
The question I have is do I use my cpp disc/disc frame mount prop valve with the Wilwood 260-8419 Adjustable Proportioning or do I remove the cpp one from the system and use a distribution block with the adjustable prop valve?
Thanks.
dontlifttoshift
06-06-2018, 06:39 AM
I like adjustable prop valves and you should never have two in line.
chevelletiger
06-06-2018, 06:00 PM
Thanks.
Removed the factory prop valve and will run lines to a brake tee.
