    View Poll Results: Which Cast Wheel?
    Voters
    7. You may not vote on this poll
    • American Racing
      4 57.14%
    • XXR
      3 42.86%
    • Konig
      0 0%
    Results 1 to 17 of 17
      Jul 2017
      Cast Wheel Showdown
      When trying to find 18x10 wheels for my Daily Driver, there aren't many options for a Forged Wheel that fit my budget AND look appealing to me.
      So I hope some of you can give me guidance on what brand of Cast Wheels I should get.
      With a budget of $250 per wheel, my options are limited to:
      American Racing
      XXR
      Konig
      Thank you!
      May 2013
      Colton Ca.
      What car? What rim style from each manufacturer? What back spacing options do each offer for which ever rim style?
      Ahmad B.
      Oct 2011
      We need more info on backspacing. There’s plenty of Chinese manufactures that make cast wheels just depends what style and backpacking your looking for
      Jul 2017
      Thank you for the replies.
      It’s for my 1970 Buick Skylark. Looking to run 18x10 squared. Backspacing on these rims is more than I need, which is ok because I can just add spacers. Final backspacing should measure anywhere between 5.5 and 5.75 inches. I plan on upgrading to discs which can push the wheel outwards, so the greater the backspace, the better. I’ll be able to adjust it with spacers after.
      As for rim design from each company,
      XXR 521
      American Racing Torq Thrust VN215
      Bolt pattern 5x120 or 5x120.65 (any is fine)
      Any hub bore is fine, I can use hubcentric rings to adapt the difference.
      Nov 2002
      Georgetown,TX
      American's VN215 is available in an 18x10 w/5.75" backspacing (+6 offset) Those numbers should be fine, on the rear. Don't think they will work on the front, though, and especially not with spacers.
      If you just have to run the same size wheel & tire, at all four corners, I would go with 18x9.5's w/5.75" backspace (+12 offset) and 275/35/18 BFG Rivals. Yes, that route will cost more money but they will fit your car w/o mods.
      https://www.ridlerwheel.com/695-grey-ml/
      18x9.5
      5 on 4.75
      5.49" Backspace
      It's below your budget so it looks like it checks all the boxes if you like the style. I have these, fit and finish is excellent.
      Lawrenceburg, TN
      just my 2 cents
      I have use the XXR brand for several years without issues and at many venues, for an entry brand the XXR are well built then move up to the next level brand like US mags as you know the skys the limit, but cast wheels are pretty good
      here is a set on NCM these are 18x9.5 all four with 275 tires
      and the newest set and these are 18.10.5 all four with 315 tires
      Oct 2011
      For Chinese manufacturers most use mm offsets. You can use this tool to convert from inches to mm: https://tiresize.com/wheel-offset-calculator/ (click on the offset converter tab)
      18x9.5 is probably a more widely available size than 18x10 and that .5 inch won’t change much as far as how wide you can go. Try eBay and just type in 18x9.5 wheel then on the side there is different offsets you can pick to narrow down your choices.
      Also if you don’t like the finish say for example wheels you like are only available in blue and are heavily discounted you can take them to any powdercoater and they usually charge $75 to sandblast and powdercoat per wheel. That’s how I found my rims they were the only 19x12 with my backspacing but they were GOLD for $185! I found them on aspiremotoring.com they have a lot of wheels for great prices
      Aodhan DS02 come in 18x9.5 with 15mm offset which is pretty close to 5.75”
      https://www.aspiremotoring.com/produ...-machined-face
      Jul 2017
      Quote Originally Posted by alocker View Post
      18x9.5
      5 on 4.75
      5.49" Backspace
      These do look quite similar to the American racing ones. Im gonna give it a look. Thank you!
      - - - Updated - - -
      just my 2 cents
      Racing proven!! Lol. Defintely gives me a different outlook on this brand. Didn't think they'd hold up to racing standards
      Jul 2017
      Quote Originally Posted by joeko23 View Post
      After your comment I had to give myself a reality check to realize that there are much more wheels available in 9.5 than 10.0
      And youre right, its probably a really negligible difference in that .5 inches
      Thank you!
      Thank you for the
      Nov 2002
      Georgetown,TX
      Since those wheels are available in 5x120 bolt circles, instead of 120.65, what hubcentric spacers are you using, Joe? Those wheels are certainly priced right.
      Practically everyone measures offsets in millimeters.
      Sep 2010
      Orange County, CA
      Have you looked at TSW wheels? They have been around forever and are right at your budget. Im not too sure about their sizing, but they do have some nice designs.
      Jul 2017
      Quote Originally Posted by 65 drop top View Post
      Yoooo, I just found those like last night! Crazy coincidence lol. But yes, they fit my budget and they have some nice styles. They are my first choice as of now.
      Doing some more research, everyone on import forums bashes and hates on cast wheels cause they are weak and crack, etc. Come to find out that OEM wheels on 99% of today’s cars are cast, and you can have them for years before they attain any significant damage that requires new wheels.
      But thank you for mentioning TSW, I will most likely go with them
      Sep 2016
      I'm in for more reviews on cheap wheels lol
      1993 Fox Body...its in the works
      https://www.pro-touring.com/threads/...72#post1249772
      1972 Nova...OUT OF THE BARN!!!!! Build coming soon!
      IG:@kdmerritt5 for more
      May 2007
      Chicago, IL.
      Billet Specialties Speedway Wheels
      Check out the new Legends Series Speedway. Starting at $210 per wheel. Offers you an alternative.
      Titanium with machine lip in stock now. Full polished version coming July
Size:  14.2 KB Name:  SPEEDWAY-POLISHED-F-01.jpg
      Click here for more Information
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by Billet-Specialties View Post
      Any chance of offering those wheels in an 18x9 and 20x11 sizes?
      Apr 2020
      Rodney, did you run the same size all around so you could rotate them?
