View Full Version : Vintage Air Gen II in 68 Camaro
tumper93
05-16-2018, 11:13 AM
I see that everyone seems to run the Gen IV in the First Gen Camaros and don't understand why. I am wanting just heat in mine but if I am going to install it I mine as well plan for adding the A/C parts in the future. Is there any reason a Gen II will not work instead of the more expensive Gen IV. I see it is a bit smaller too
dontlifttoshift
05-16-2018, 12:15 PM
I have installed a lot of GEN II units in a lot of different cars. If I can make a GENIV work, I do. It is a better unit than the II in every way, it moves more air, the evaporator core and heater core are separate in the IV, the variable fan speed is nice and not being limited by the capillary tube on the controls makes packaging easier.
Factor that with the fact that there is a GENIV kit already engineered to fit your car and the extra money is well worth it.
Bad Bowtie
05-17-2018, 12:28 AM
If I recall the Gen II is also vacuum operated as opposed to electric door driven servo motors, correct me if I'm wrong. I installed 1 Gen II many years ago before the Gen IV's came out and have never went back. What was nice was that DSE made a nice bracket for the Gen II's in the 67-69 Camaros. Now they only produce Gen IV bracket for 69 Camaro.
Best of luck with which ever you choose.
BB
tumper93
05-17-2018, 03:02 AM
I like the features of the IV BUT I only care about heat so I can drive in late fall and early spring, not the winter. I may add the A/C someday but right now I have no plans to make that operational. That is why I am leaning more towards this one plus when I do make it work it will only be used if the wife rides and it is super hot. I hate A/C in cars and prefer the windows down even at 100 degrees! From what I have read the Gen II will do everything I need but wanted to ask for what others had done. It is a electric servo unit now also
CapSS92
05-18-2018, 07:46 PM
I used a Gen II Compac in a 69 Camaro with a 2010 dash and it worked great. Fit perfect and works just fine. I've also used the vacuum version in a 55 Nomad and it cooled just fine. If it works for your application I say go with it. You can see some pictures of it installed here:
https://www.pro-touring.com/threads/79909-2010-Camaro-interior-in-70-chevelle/page2?p=1262630&highlight=#post1262630
Alex
