Johnzee67ls3
05-13-2018, 11:43 AM
Doing some shop cleanup and getting rid of extra parts. Parts will be shipped from 89431 with shipping paid for by buyer. Can pay paypal. For quicker response you can send me an email [email protected].
Moroso oil pan part#20142 and pickup#24050. Only used for mock up.-$350
152441152442152443
Brand new Crower Cam 279, 285 .644 lift 113LSA. See picture of cam card for full details, to be used with solid rollers.-$400
152444152445
Clayton Machine ignition coil covers part#LSC-01-M. Minor scratches, ready for paint. comes with mounting hardware.-$150
152446152447
New Derale PWM 12’’ dual fans part#66842. 26’’ wide, 18’’ tall, 4’’ thick. Never installed, comes with all necessary electronics.-$400
152448152449
Original 1967 Camaro gauge cluster, everything worked when pulled.-$100
152450152451
New Holley spacers part#HLY21-1 and HLY21-2. The 21-1 is used for standard belt spacing on passengerside a/c bracket, the 21-2 is for Camaro (newer f body) passengerside spacing for a/c bracket.- $40 each
152452152453
ATS/Speedtech engine mount plates part# SDP-ATS70001 Used for mock up, ended up going with Hooker mounts with my application. Energy suspension mounts, the lower metal ears are ground off. I will throw them in for free if full asking price is paid.-$100
152454
Remanants of universal intake kit Airaid part #101-351. What you see is what you get- still some good pieces to fab up another intake system. You will need a couple rubber pieces that connect the hard plastic pipes. Air filter has small dent in mesh.-$150
152458
LS MSD ignition coils part #MSD82648. Bolted on then taken off to go a different direction, don’t think it matters but they were used with a redone truck harness.-$300
152461152462
Only used for mock up- Unisteer rack and pinion part #UIS8010540-01. Comes with what is pictured: Steering arms, pressure/return fittings, mounting spacers. Depending on application you will need longer lower control arm bolts for mounting. It has a couple of scratches from engine R&R and the heads of the fittings are ground down from clearance issues. It is my understanding this rack and pinion works best in the speedtech subframe w/LS or stock subframe with older SBC. With Hooker mounts and headers I did not have any luck incorporating this with the LS in factory subframe.-$600
152463152464152465
152441152442152443
152444152445
152446152447
152448152449
152450152451
152452152453
152454
152458
152461152462
152463152464152465
