Motoracer838
05-08-2018, 12:46 PM
Instead of compressing the spring and wrestling the thing in place and fighting with getting the spring compressor out, like this.
https://static1.pt-content.com/images/pt/2018/05/40175418280_eb4c4f8549_c-1.jpg (https://flic.kr/p/24dawaw)IMG_20180508_142056328 (https://flic.kr/p/24dawaw) by Joseph Martin (https://www.flickr.com/photos/159706764@N04/), on Flickr
Don't use the upper half of the compressor, instead drop the bolt through the upper shock mount hole and engage with the lower half of the compressor (note this works for through sock applications, where the shock rides inside the spring.)
https://static1.pt-content.com/images/pt/2018/05/41263464994_b497b2b97e_c-1.jpg (https://flic.kr/p/25Sj3xC)IMG_20180508_142443502 (https://flic.kr/p/25Sj3xC) by Joseph Martin (https://www.flickr.com/photos/159706764@N04/), on Flickr
think of the spry can as the top of the frame where the shock comes through... Note you need to make sure the spring is clocked correctly before compressing the spring or you'll have to run it back down turn the spring and do it again, also it may take a little prying to get the spring in the pocket, but I find this way much easier and safer...
Joe
Joe
