View Full Version : Tailpipes 2.5” vs 3”
XLexusTech
04-30-2018, 04:46 PM
500 hp naturally aspirated ls3 I am going with 3” to the muffler starting to wonder if I am going to be able to get the 3” over the rear suspension...so I am considering 2.5”
what would the performance impact be ?
1985olds
04-30-2018, 05:18 PM
Hopefully this answers you question.
https://m.youtube.com/watch?list=PLGvTvFzdMg_O2T3UdUEt5dIHutSOu7srE&v=_PVXvHkr-Vs
68Formula
04-30-2018, 05:45 PM
Coming out of the mufflers, the smaller pipes won't make a lick of difference except maybe knock a decibel or two off.
XLexusTech
05-01-2018, 03:18 AM
Kinda but not really they conclude that through the muffler 2.5 to 3” third is a notacable difference .. but I am asking a lot after the muffler only and they are at 600+ hp with a larger cid (more air) engine so too many significant differences to draw any conclusions
Thank you for the link it definitely helped
csouth
05-01-2018, 07:15 AM
You could also step down after the muffler and run 2.5" tailpipes. The exhaust will have cooled by then making the gasses more dense requiring less space.
XLexusTech
05-01-2018, 12:48 PM
yes thats what i was asking. would that step down have a large performance impact @ the 500 HP level..
andrewb70
05-01-2018, 01:42 PM
I'd say no difference.
68Formula
05-01-2018, 02:24 PM
Yup, no difference.
MAGONSTERZ68
07-23-2018, 10:00 PM
Yup, no difference.
agreed no difference other than sound, dynoed car with full 3" over the rear end, 467 to the rear wheels.
later modified with a set of spintech traverse mounted, 3" in and 2.5 out for the sake of dropping a decibel or two, hence the second set of cans.....and re-dynoed at 461 to the rear.
65 drop top
07-24-2018, 06:49 PM
Should be no noticeable difference with the 2.5” after the mufflers. Even 2.5” from the headers back wouldn’t hurt much either, if at all. 500 hp is about the point when you would consider 3”.
CarlC
08-15-2018, 03:18 PM
Flowmaster makes a very nice long-transition 3" ==> 2-1/2" coupler. 3" to before the mufflers, the transition, 2-1/2" in/out mufflers, then 2-1/2" tailpipes. I had this setup on the Camaro for years with good results and quite reasonable noise levels with Magnaflow 17" case length mufflers.
There used to be a Dynomax catalog that listed horsepower ratings for mufflers. If memory serves a single 2-1/2" muffler was rated for well over 600hp.
