View Full Version : 69 Camaro LS3 with Entropy radiator upper rad hose needed
DT69Cam
04-28-2018, 02:55 AM
What have you guys used for an upper radiator hose for your ls3 swap in a 69 Camaro? I have a hose that was recommended from a Lincoln that seems to fit the bill, (I haven't received it yet). I was just wondering what other ideas were out there. Anyone make stainless tube in lieu of hose ?? The hose entropy recommends is not for my style water pump outlet.
XLexusTech
04-28-2018, 03:09 PM
Plus one same question.. I have the lower but the upper I have yet to buy... pass side inlet and outlet btw
dhutton
04-28-2018, 04:25 PM
https://www.ebay.com/itm/Radiator-Coolant-Hose-Upper-Continental-Elite-61782/161820558093?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
Don
130fe
04-28-2018, 06:23 PM
My LS pump (LS2 vette style) has both connections on the passiside. I used this hose number 22358 for my upper hose on my Entropy.
XLexusTech
04-29-2018, 03:53 AM
Thanks guys pic definitely helped I have the number of the gates hose and it is very large like above ... once you see that you are trimming off half of the hose you see how it will work .. thank you !
DT69Cam
04-29-2018, 10:12 AM
I used the Dayco equivalent of the hose Don recommended (Continental #61782). The Dayco part# is E72126. Lil trimming and it worked perfectly. My water pump outlet is more towards the drivers side, by PS pump.
MAGONSTERZ68
07-01-2018, 07:27 PM
here is the one i used, car has a 2010 camaro / truck water pump with inlet located driver side of pulley.
154085
