View Full Version : full throttle signal fly by wire
XLexusTech
04-21-2018, 04:48 AM
Hey folks. Wiring the vintage air today ,,, thief is a full throttle wire which will cutoff the compressor on full throttle
Has anyone used this? Where can I pickup full throttle signal?
Ls3 psi conversion harness ... fly by wire
dhutton
04-21-2018, 04:57 AM
I would incorporate a Lokar switch into the pedal bracket to generate the signal
https://www.summitracing.com/parts/lok-s-68154?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-lokar&gclid=EAIaIQobChMI3eyRhrXL2gIVCrXACh1T7w1jEAQYBCAB EgLA6fD_BwE
Don
badazz81z28
04-22-2018, 08:42 PM
So, I did not install one of these. Why would you need it? RPMs kill the compressor not WOT. If you plan to blast the engine to 7000rpms, turn the AC off.
12sec ss
06-15-2018, 07:27 PM
Use a window switch off the tach
andrewb70
06-16-2018, 01:25 PM
Load and RPM are not the same thing. Presumably he wants the compressor off at WOT, even if at 2000rpm. How does an RPM window switch do that?
TXsilverado
06-20-2018, 12:52 PM
What pcm are you using? let it give whatever signal you need like the OEM does.
