View Full Version : Is a power steering cooler necessary for my application
SSLOW6.0
04-17-2018, 06:08 AM
I have an 86 Mont Carlo SS, LS swapped with truck accessories, factory Saginaw steering box. I am running 245/45/17 Bridgestone RE-71rs. I have a small power steering cooler laying around, I'm wondering if it is worth the effort and weight to install. Any thoughts?
GoodysGotaCuda
04-17-2018, 02:33 PM
I didn't think I needed one, until I measured 275* fluid after a normal drive. Put a cooler on it.
anthonys 69
04-17-2018, 02:40 PM
I work on a lot of different vehicles from mine vans to jags, Camaro's, mustangs they all have some kind of power steering cooler. some better than others. I would with out a doubt put some kind of cooler on. good luck.
btmatt
04-18-2018, 07:34 AM
I have an C&R integrated cooler on my Camaro. I have not measured temps (before and after), but definitely noticed a difference in foaming of the fluid FWIW.
130fe
04-18-2018, 02:40 PM
BTMatt, are you having issues with foaming using the C&R cooler?
chuckd71
04-18-2018, 06:15 PM
Lots of trucks in salvage yards have them, in all different shapes and sizes, most with hoses attached. I grabbed a long thin one that fit right beneath my radiator for a dollar or something. No reason not to run one.
btmatt
04-19-2018, 06:27 AM
130FE, I was having problems before I added the cooler (rad). Looking back, the additional capacity probably helped more with that.
Big_KID
04-19-2018, 06:43 PM
Since the op is using truck accessories and someone else mentioned using a stock truck ps cooler... I thought I would chime in. Granted I have also added hydroboost, after a couple consecutive autox runs my 2000 Silverado's ps pump is whining pretty good and puking a small bit of fluid. I am looking to remove the hydroboost to reduce some of the load on the pump along with replacing the stock cooler with an aftermarket unit. The stock GMT800 cooler is just an ~12" loop of steel hard line thru a series of steel fins. Although adequate for normal truck duties, it doesn't have a high enough transfer rate to handle performance driving. I would presume the ps system would get pretty warm with no cooler at all.
MAGONSTERZ68
04-20-2018, 09:31 PM
doit! well worth the investment to dissipate heat and prolong duty cycle.
