View Full Version : Here We Go Again: Honor Flight Camaro and the 2018 One Lap of America
CarlC
04-03-2018, 09:28 PM
https://i.hmjimg.com/images/2018/04/03/oloa2018.md.jpg
It’s that time again for a bunch of “not quite right” folks to get together starting May 5 for the 33rd One Lap of America. With a full field of 85 cars and 3700 miles of driving + track time, this is shaping up to be one of the largest OLoA events in years.
As in previous years my codriver Jon Mahn and I will be flying the Honor Flight banner to help raise awareness for a very noble cause.
http://www.honorflight.org
Behind the scenes we have been preparing the car with a series of upgrades to items that were in pretty poor shape. The first was the exhaust system. Though the David Pozzi tuned ;-) headers were still in good shape the Dr. Gas crossover and both mufflers had many cracks. One muffler just about fell apart in ˝, the other was about to spit out a full end cap.
https://i.hmjimg.com/images/2018/04/03/20161228_171853.md.jpg
With reliability and serviceability in mind, the new system consists of all stainless components, flex joints, Magnaflow “X” crossover and mufflers, ball/socket header flanges, and full tailpipes. The mufflers are a 17” long case 3”in/out and 3” tailpipes exiting in the stock location. It’s super tight, but the driveshaft can be dropped out easily and the whole exhaust system including headers is on the ground in about 45 minutes. A big thanks goes out to Primo at JCG Restorations and Customs who turned my tack welds into something much more presentable.
https://i.hmjimg.com/images/2018/04/03/20161227_160249.md.jpg
https://i.hmjimg.com/images/2018/04/03/20161228_165315.md.jpg
https://i.hmjimg.com/images/2018/04/03/20161228_165015.md.jpg
Afterward the system was ceramic coated inside and out to help keep the heat in. Tunnel and over-muffler heat shielding was added as well thanks to Larry Callahan and our mutual need to overbuy stuff. Here’s the system after 15 months of track days, rain, etc.
https://i.hmjimg.com/images/2018/04/03/20180329_094411.md.jpg
Next up was the differential. The 12-bolt center section has been super reliable, but the outboard bearings require changing at least once a year. The adapted Ford single row deep groove ball design is fine for most applications, but one “off” on a road course curb would mean nasty noises shortly thereafter.
With an eye to future upgrades, a call to Jay at MillerBuilt started the process of doing something a bit oddball. Instead of building a traditional 9”, homage was paid to David Pozzi by using a 12-bolt housing that he donated many years ago. It needed new tubes and main caps but the center was fine.
The process started with determining what the flange-to-flange width needed to be with C7 Corvette hub assemblies. The C7 hubs are not only stronger than the Ford part, they also have very little side deflection that leads to caliper piston knockback. They also have an integrated wheel speed sensor.
The MillerBuilt kit used is a weld-on design so it was important to know how long each differential tube and floater axle needed to be with the yoke centered appropriately. Jay listened to my nutty ideas on the how and why I wanted to things in a peculiar way, suppled the fixtures to weld the ends straight to the tubes, and dealt with several unforeseen problems in a very professional and timely manner.
The 3.73:1 gears are US Gear with a REM/high polish finish mounted on an Eaton limited slip assembly. The Mark Williams main caps were milled by me in a friends Bridgeport and are seriously beefy. My concern about gear noise and durability have so far been unfounded as these are quieter than the mid-90’s vintage Richmond gears that were in the prior differential. Redline 75W140 gear oil keeps things well lubricated.
https://i.hmjimg.com/images/2018/04/03/20180329_101014.md.jpg
Savy 1968-1969 owners will notice one of the oddball differences in this setup vs. a traditional staggered shock caliper placement. Yep, it fits. This is a C6 RH, the other side is C6 LH. The parking brake cables are on the to-do list. The components looked a lot nicer before all of the track and autocross days.
https://i.hmjimg.com/images/2018/04/03/20180329_0940371.md.jpg
https://i.hmjimg.com/images/2018/04/03/20180329_094301.md.jpg
Again Primo worked his TIG magic on the ends.
https://i.hmjimg.com/images/2018/04/03/20180329_104145.md.jpg
And finally, it’s all buttoned up with the differential cover also donated by Senor Pozzi. The leaf spring mounts were welded on with the proper clocking of the axle so that no angle shims were needed. The exhaust is a very tight fit around the differential, sway bar links, fuel tank, leaf springs, and quarter panel.
https://i.hmjimg.com/images/2018/04/03/20180329_094322.md.jpg
More to come over the next few weeks, but the April 20 ship date is looming so we have to stay on task with getting the car ready and the drivers minds tuned to each track.
andrewb70
04-04-2018, 06:22 AM
In for updates!
TheBandit
04-04-2018, 06:48 AM
Looks very nice Carl! What else is on the list before April 20?
CarlC
04-04-2018, 12:17 PM
What's on the list, or what will get done ;-)
Brake ducting, nut-and-bolt, detail the load/pack, graphics, and shock testing/tuning. We have a final trackday at Buttonwillow on Saturday to test the new Michellin Pilot Sport 4S tires, tweak the shock package, and hammer out small details.
Martin71RS
04-04-2018, 12:25 PM
I'll be watching this.....! good luck Carl ! :-)
CarlC
04-04-2018, 02:28 PM
Thanks Martin!
CarlC
04-09-2018, 10:58 PM
Final shakedown at Buttonwillow went better than expected. We ran three full 20-minute sessions with the first dry, the second kinda-dry, and the third quite wet.
It was a day of several "firsts" where our confidence was high but can only be proved where the rubber meets the road. This was the first time out with the new Hotchkis monotube shocks freshly built and tuned by Fox, the first time with a new set of C6 DBA rear rotors from Kore3, the first time for the new front brake ducting, and the first for the newest Michelin Pilot Sport 4S tire.
At Motorsports Ranch in 2015, the track with the hardest braking of the event, the brakes were getting marginal with ambient temps in the high 90's. With the reviews of the 4S tire being what they are we felt that the added grip over the prior Pilot Super Sport's would overtax the brakes. Some ducting was needed.
The original idea to make a major addition to the front of the car was shelved due to time. So, Plan B was to come up with something that may not be as good as Plan A, but good enough to get us through OLoA. Let the gutterballing begin..... ;-)
One big challenge for ducting a big-tire 1st gen is that there is little room to work with. Any kind of rotor shield tube attachment is out.
Jon and I busted out our portable wind chamber (AKA the strongest fan we could find) and noted that very little air was entering the wheel from the inside. The JCG Restorations and Customs splitter and spoiler was keeping the air in that area pretty dead. Our highly engineered solution was a Home Depot plumbing run to fetch some ABS tubing and a 45* street ell. The tube is cut at a steep angle to match the screen, the inlet edges radiused, and mounted on the top by a simple tab using existing grill screws. The lower section is secured with Velcro straps where the straps were secured with a single screw centered on the tube. The outlet bracket uses the Hotchkis sway bar mounting bolt for one end and an unused OEM hole towards the front. Not only is it more secure than expected, we were shocked at how much air was moving toward the rotor. The ABS is not glued together so adjustments can be made and service easier.
https://i.hmjimg.com/images/2018/04/09/20180409_230122.md.jpg
https://i.hmjimg.com/images/2018/04/09/20180409_230425.md.jpg
https://i.hmjimg.com/images/2018/04/09/20180409_230152.md.jpg
The Fox-tuned Hotchkis shocks are all new as well utilizing the latest housing design. Since we first worked with Fox back in 2013 to sort out the valving we have been completely impressed with their performance. Since it had been five years, two OLoA, and a boatload of track days, it was time to go to the latest design. We were not disappointed.
https://i.hmjimg.com/images/2018/04/09/20180407_122035.md.jpg
When the rear axle was built using the Millerbuilt C7 kit, the rotor was upgraded as well from the Gen4 F-body part. Being that I do have a, umm, "frugal" side, I opt to try and make consumable choices based on performance and cost. Tobin made a great call on the DBA front rotors, so his suggestion to do the same for the rears was an easy choice. Hawk HPS pads, stainless steel caliper pistons up front, ducting, and Wilwood 600* fluid round out the system.
Session one was dry so the car was pushed hard to find the weaknesses in the brakes and the limits of the tires. Prior to this testing, the HFC was 2-3 seconds slower per lap than Jon's C5 Z06 with 315's all around and suspension upgrades. Though we are frenemies on-track, we were happy that the HFC was now running three seconds faster than the C5. No brake issues, not even any smell or odd colors on the rotors, just lots of dust.
https://i.hmjimg.com/images/2018/04/09/20180407_1220111.md.jpg
Session two with Jon behind the wheel netted similar performance with no issues. A few lightly damp sections were no cause for concern.
Session three turned out to be the most beneficial. With a quite wet track the new 4S's were superb. Tire Rack's latest test of the 4S with several other competing tires had an interesting comment. When asked what should be changed in the tire, their answer was "Nothing." We agree. It's a significantly better performing tire than the Pilot Super Sport in both wet and dry conditions.
Next up for tomorrow, graphics......
Chad-1stGen
04-10-2018, 10:19 AM
I always love reading about your upgrades and tweaks! Best of luck on OLoA! I'll be following along.
CarlC
04-10-2018, 10:27 PM
One day Chad, one day.... ;-)
One quick image for the day.
My cousin Adam Oliver Zanutto is riding along with my dad and Team Honor Flight.
Adam's grandfather, Oliver Zanutto, was dads lifelong best friend. Oliver married dads little sister, Julie.
On leave Adam would visit as the young learns from the old bull.
In 2006 Adam was killed by an IED during his third tour in Iraq.
I drove dad and Oliver to the funeral in Bakersfield. I've talked to those guys for my whole life but could not find any fitting words.
Adam's father Ricky helps run the Bear Valley Bear Valley Springs Veterans Association and Honor Flight organization based out of Tehachapi, CA. Talk about a small world....
https://i.hmjimg.com/images/2018/04/10/20180410_0931111.md.jpg
04-12-2018, 07:13 PM
Carl, your Camaro keeps getting better and better! The ducting looks good & I think it's very very important on heavy braking tracks. I had a scare at New Jersey Motorsports Park in 2010.
CarlC
04-16-2018, 06:09 AM
Thanks David. The inlet is not what I had in mind. A center-mounted inlet, rectangular, with dual inlets on the lower spoiler would be ideal. That means lots of sheetmetal work along with a new power steering cooler, line routing, etc. This is a Band-Aid but it was pretty effective at Buttonwillow.
This is the track that that keeps us up at night. If we were regulars and used to the track likely it would not be nearly as hard on the brakes. We're running three different configurations in one day. The left-hand and right hand can be separated via the junctions near turns 4-5, then combined into a 3.1m single. Ignore the green. Fast and many blind sections. Yikes.
https://i.hmjimg.com/images/2018/04/16/Cresson.md.jpg
CarlC
04-30-2018, 08:55 PM
The HFC has been loaded, moved, and arrived at her temporary home just south of Chicago. On Friday we pick her up and head to South Bend.
https://i.hmjimg.com/images/2018/04/30/20180420_1137411.md.jpg
We are very pleased to have Hotchkis Sport Suspension on board with us again this year. The latest shock package (the brains of the suspension) and the new Michelin Pilot Sport 4S have again transformed the car. We are very much looking forward to competing in the Vintage class, a combined foreign and domestic event, this year. There's several LS-swapp'ed 944's, 911's, an NSX, and The Original One Lap Camaro in the class.
https://i.hmjimg.com/images/2018/04/30/side.md.jpg
And like prior OLoA's, we have some celebrities along for the ride. Travis Pestrana in a 2018 WRX and Andy Pilgrim in an M4 (maybe) are in our merry band.
Getting photos uploaded on the forums can be challenging while on the road. Most of the daily updates can be found on the Honor Flight Camaro Facebook page.
jlwdvm
05-03-2018, 05:54 AM
I will be routing a duct to the front brake area on my 69 firebird. Just wondering how much of a difference you feel the ducting made? Space is definitely limited!152179152180
BonzoHansen
05-03-2018, 07:57 PM
Looking good Carl. Keep up the good work
nvmyss
05-09-2018, 07:58 AM
Carl would you like a set of flat caps if I sent them?
https://static1.pt-content.com/images/pt/2017/10/At8iIBPb-1.jpg (https://imgur.com/At8iIBP)
https://static1.pt-content.com/images/pt/2017/10/tBUynTMb-1.jpg (https://imgur.com/tBUynTM)
Motown 454
05-09-2018, 08:14 PM
Keep at it Carl, you guys are doing great.
