View Full Version : 1970 Chevelle 6.0 LS
RadLS67
03-28-2018, 07:50 PM
1970 Chevelle flat black located in Houston, TX
17'' US Mags with BF goodrich tires
Speedtech chassis brace and frame box kit installed, frame cleaned and painted with new body bushings. Has all sheetmetal minus rear bumper. The floor pans, quarter panel, front inner fenders, headlight pans are all new. HVAC hole in firewall filled and smoothed. All glass minus windshield and 1 quarter window. Original chassis harness and gauges. Complete bolt kit still in packaging.
Front suspension has brand new shocks, springs, tubular control arms, steering box, ball joints, tie rod ends, front disk brakes, brand new brake lines, proportioning valve, master cylinder/vacuum booster.
Rear suspension: OEM 12 bolt with drum brakes, original control arms/bushings
Dash needs work but good base if modifying. I have a 2008 chevrolet truck tilt steering column and steering wheel mocked into place, it is a column shift with tap up/tap down buttons to control trans as well as cruise control.
The original rear seat that has seen better days, 2 cloth non-original buckets.
Engine: LY6 6.0L heads have been taken off and cleaned, has LS9 head gaskets, head studs, new lifters and trays, LS3 intake with LS3 fuel rails and injectors with truck throttle body. Has an F-body oil pan installed that sits flush with the bottom of the frame crossover. All brand new gaskets throughout. All truck accessories including a/c. Has full harness and E38 ecu with a standalone wiring kit. New mounts and adapter plates
Trans: 6L90E has brand new mount, trans tunnel has been modified to fit transmission, HD slip yoke.
clean title in hand $12,000 obo
67Steven
03-29-2018, 07:38 PM
Too bad you're too far away - If you get it to my house I'd give you your asking price!
1sikride
03-29-2018, 08:05 PM
Let’s see the column
RichieRath
04-04-2018, 10:38 AM
Sold yet?
RadLS67
04-05-2018, 05:19 PM
sold
