View Full Version : Mopar hemi 6.4l 392 crate engine non mds hot rod swap
Jketron
03-28-2018, 01:53 PM
I have a 392 Hemi motor ready to ship out on a pallet. Shipping via UPS ground is typically $400
The engine was pulled from a low mileage wreck and was running the day it was pulled. The engine has 7400 miles on it. The engine will come complete with the wiring harness, exhaust manifold, o2 sensors, 392 covers just like you see in the picture.
A brand new crate from mopar will run you $8500 and that's without the $100 covers that say 392 Hemi on them. You will also get the factory started and save another $350.
This a Non-MDS motor which is exactly what you want for your hot rod upgrade.
This setup would cost you $8950 for the motor, covers, and starter.
Save yourself $2950 bucks and put that towards something else in your car.
I'm selling this setup for $6000 delivered.
I have video of the motor running, if you decide you are interested I can send it to you.
MOP68303090AA MOPAR
Features:
•Gen III HEMI V8
•485 horsepower
•475 lb.-ft. of torque
•392 cubic inches displacement
•94.6mm stroke x 103.9mm bore
•Peak RPM 6400
•Aluminum, HEMIspherical chamber cylinder heads
•Cast Iron Block with 4 Bolt Powder Metal Caps
•Premium fuel recommended
Includes complete engine assembly with:
•Water pump
•Fly wheel and clutch
•Front sump oil pan
•Intake manifold with throttle body
•Fuel injectors
•Coil packs
