View Full Version : 2nd gen TA with rear disc brakes -how to get E brake functional
gscherer78ta
03-28-2018, 04:57 AM
I have already converted to the 4th gen rear disc brakes and I also made the shocks non staggered. I am looking for ways to get the E-brake working. I retained the brake cables from the 4th gen donor so, I just need a way to connect the factory cable to the 4th gen cable. How have any of you done this?
Greg
232_ray
03-28-2018, 04:32 PM
Easiest and best way I found was to just have a local shop make me what I needed with the right ends and to size that I needed for my 1969 camaro that I added Kore3 rear C6 Z06 style rear brakes. It cost me about 70/75 bucks for both cables. PM me if u want the info to the shop that hook me up.
ErikSOCAL
04-02-2018, 05:06 PM
Would you mind sharing what type of shop you went to and what you spec'd out? Would be interested if I can find someplace local but believe the lokar set might still be the best way to go..or even original if a little extra length didn't get I. The way..
232_ray
04-02-2018, 09:52 PM
Yeah no problem. The shop is called Control Cables the website is www.controlcables.com if the lokar set is the one I looked into these guys will beat it. It'll literally look factory. Theses guys made them to my exact specs with the correct ends crimped on. They even made my intermidiate cable. Total was less than 100 bucks for 3 cables. They are awesome literally 1 day turn around. Stopped by right before closing on a Tuesday by lunch the next day they called and said they were ready. The hardest part was me being nervous about the exact measurements. But the guy even said to measure on the longer side 1/2" longer which I did and was good no problem. Give them a call they are worth it totally.
gscherer78ta
04-03-2018, 04:50 AM
Saw your PM, thank you!
