View Full Version : "LS" brake upgrade warning
Motoracer838
03-24-2018, 10:02 AM
For those running the "LS" brake upgrade on G bodies, S10's and possibly 3rd gen F bodies. (3rd gen's mount the caliper a little differently)
Check your clearances... I had a "moment" driving Frankenstine recently, a loss of brake pressure in traffic.https://www.pro-touring.com/threads/126961-Project-Frankenstein
https://static1.pt-content.com/images/pt/2018/03/40281315224_dea74654fb_c-1.jpg (https://flic.kr/p/24nwgCU)IMG_20180324_113202737_HDR (https://flic.kr/p/24nwgCU) by Joseph Martin (https://www.flickr.com/photos/159706764@N04/), on Flickr
The banjo bolt is making contact with the frame when the steering is at full lock during suspension travel. I'm just now getting to check to see if the banjo bolt is damaged or if it's the caliper...
Joe
andrewb70
03-24-2018, 01:40 PM
Joe,
Thanks for posting this. It looks like when the caliper bracket was designed, the clocking of the caliper was not carefully considered.
kochevy67
03-24-2018, 01:41 PM
I am so glad I saw this post. I am building a second gen for my son and will definitely pay attention to this.
1985olds
03-25-2018, 03:59 PM
Thank you, this must of been what was happening to me when I put my c5 calipers on. Who made your bracket?
Motoracer838
03-26-2018, 10:39 AM
I made the brackets from info off the net.
Joe
1985olds
03-26-2018, 03:52 PM
Joe
Got it, thank you
Motoracer838
05-08-2018, 01:13 PM
Wanted to update this thread, found some button head banjo bolts at Summit, made by Russell
https://static1.pt-content.com/images/pt/2018/05/27113705217_4af5b22703_c-1.jpg (https://flic.kr/p/HiWPWa)IMG_20180504_190311323 (https://flic.kr/p/HiWPWa) by Joseph Martin (https://www.flickr.com/photos/159706764@N04/), on Flickr
This gave me enough room without having to modify the steering stops or heating and denting the frame...
Joe
jlcustomz
05-08-2018, 03:33 PM
There always seem to be an endless amount of little unthought about details out there to get us. Guess you have all sorts of room for variables when mixing up parts
Still planning to use the 98 to 02 calipers on the front of my g-body, though redesigning bracket myself for 14" vette front rotors. Haven't heard of any other g-body issues to date.
One more thing on my check list now.:hmm:
Motoracer838
05-09-2018, 10:22 AM
It's the details that make the difference... with 14" rotors, you''l probably clear the frame with room to spare, I'm looking to stepping up to 13" when I do the disc brake 8.8, the stock drums look ridiculous in the 18" wheels... Not much bigger than the spacers... :lmao:
Joe
1985olds
05-09-2018, 12:57 PM
Joe
Thanks for posting your solution. I was looking for this thread to see if you found a one. I am ordering those banjo bolts when I get home so I can give my brakes another wack. Thanks again!
TheBandit
05-09-2018, 01:03 PM
Keep in mind the position of the caliper is going to change throughout suspension travel and steering, and will also be affected by alignment. If you're seeing contact now I wouldn't rely on just that little bit of clearance gain from a hex to button head banjo bolt. I'd think hard about reclocking the calipers or limiting the steering.
Motoracer838
05-10-2018, 04:13 PM
I ran it through it's travel while I had the springs out last weekend, that was it's tightest spot, plenty of room now...
Joe
TheBandit
05-11-2018, 06:37 AM
Great! Glad you checked.
