View Full Version : Flared or Bulged '67 Camaro Front Fenders?
TonyHuntimer
03-13-2018, 10:47 PM
Hey all!
Is anyone aware of flared or bulged '67 Camaro front fenders on the market? We need to get about 1" of additional clearance to run the wheels and tire size we're looking at running.
Tony Huntimer
TheJDMan
03-14-2018, 04:09 PM
James Shipka's 67 One Lap Camaro had the front fenders flared in such a way that you can hardly tell them from a stock fender. As I recall, they gained about 1.5" per side. Best of Show did the custom fenders and there used to be a whole series of photos in his project thread here on PT showing how the fenders were pie cut and the sections moved out. I have tried to contact both James and BoS to see if I could get copies of the build photos but have not received any response. There are a good collection of pics of the One Lap Camaro on his facebook page. If you look at the fenders you can't tell they are flared until you notice the 315 front tires. I would also like to flare my front fenders in able to fit a 315 tire up front but I don't want the flares to be obvious. If someone could get in touch with James and see if he still has the front fender mod pics it would be nice to have them back on PT.
https://www.facebook.com/TheOneLapCamaro/photos/rpp.201671151241/10154280335951242/?type=3&theater
icemanrd19
03-14-2018, 04:14 PM
Same. Would love to run 315s in all 4 corners.
dhutton
03-14-2018, 05:01 PM
A few pics of the 67-68 fender stretch process in this thread. I used his technique to stretch the rear quarters on my 69.
http://lateral-g.net/forums/showthread.php?t=23832&highlight=Fat+bottom+Camaros&page=5
Don
03-14-2018, 07:58 PM
I have a pair of new repro front fenders to sell if you need to make front “skins”. I bought JCG carbon front fenders that are bulged. Molds were taken from Blue Balz.
I welded steel skins on the rear, ganed 1.5”
TonyHuntimer
03-15-2018, 11:38 PM
David,
That's interesting. I'll talk with Scott and let you know.
Tony
03-17-2018, 03:18 PM
I saw the pics, can't find them now though. They cut of the fender side at the peak ridge running lengthwise, then used an english wheel to stretch them, then welded them back on.
I'll post some pics I do have of the finished fender.150549150548150547
03-17-2018, 03:27 PM
One strange thing done was I think James had them push the lower fender inwards to the rear of the wheel. I think to help extract air from the wheelwell. Not very noticeable but in this angle it is. A bit of a problem area was where the fender meets the lower fender extension. Clearance was tight there with the wheel offsets we had and if widening the fender you need to bring the lower fender extension out at the same time to keep the lip an even flow.
150550
Munssey
03-17-2018, 06:48 PM
Feeling your pain! The 69s got all the love but us 67 \ 68 guys are coming on strong lately.
I couldn't find a good QUALITY option either so I just plan on putting the investment out to craft some myself and do all the fancy things we've been hearing from a few friends who used to do Daytona Prototype races. Naturally carbon fiber is the goal but they will not look 100% factory which may make them bad candidates for a majority of Camaro builders who want to run a wider front fender.
TonyHuntimer
03-17-2018, 11:57 PM
If the fenders don't detract from the stock form too much (like the JCG fenders), then there's a market for them. It won't be a huge market, but there are people out there who want them. And there are people who don't even know there's an option.
Without the JCG option, the only other one is to run actual flares like the ones on Rodney Prouty's Camaro:
http://www.thestreetfighters.com/wp-content/uploads/2017/05/20170711130931-a002ef5c-me.jpg
TheStreetFighters.com (http://www.thestreetfighters.com/)
Cheers!
Tony Huntimer
Build-It-Break-It
03-18-2018, 06:05 AM
Just buy the speedtech extreme subframe and no fender flares are needed?:hammer:
TonyHuntimer
03-18-2018, 08:32 AM
It has a Speedtech Extreme subframe, but want to run 315s or 335s up front. You can do that on a '69, but not a '67-'68.
Cheers,
Tony Huntimer
TonyHuntimer
03-18-2018, 08:49 AM
Just Flare it!
150551
Rodney,
This is one of the 3 options on the table. ;)
In no particular order.
1 150552
2 150553
3 150554
Cheers,
Tony Huntimer
Build-It-Break-It
03-18-2018, 09:56 AM
Cheers,
Tony Huntimer
When I last spoke to Blake he told me you could run 315s up front but the inner fenders would be the issue? He told me slight rolling of the outer fender lip would be needed as well and that would be all (backspacing on the wheels would be around 8.25 I believe)? I'm running there extreme subframe with 295/40/18 up front and it looks like there's enough room for a 315? My cars a 68 as well.
:dunno:
Build-It-Break-It
03-18-2018, 10:10 AM
Post number 35 from Ben from speedtech states they fit a 315 up front no outer fender mods on one of their builds? He says another person fit 335s.
http://lateral-g.net/forums/showthread.php?t=52281&page=4
Zspoiler
03-18-2018, 11:11 AM
It depends on the "look" you want .Have you looked at the SCCA .IMSA road race cars of that era.?
Munssey
03-20-2018, 04:54 AM
Cheers!
Tony Huntimer
Very good point. It is risky going away from the stock look.
Chances are, ours will look quite different, probably polarizing on opinions.
Some will absolutely love them. And probably just as many will utterly hate them.
