chuckd71
03-13-2018, 09:46 AM
Selling my gas tank, the fittings I used, the Corvette filter/regulator and throwing in a new Aeromotive 11540 E85 pump in case you want to go that route. The filter/regulator has about 3,000 miles on it but the fittings should make it easy to replace if you wanted to slap a new one on. The Aeromotive tank has maybe 700 miles on it and works fine but it does need the new gasket installed. The extra pump is just one I kept on hand in case I went E85 (I am not).
Will get some more pics up once I get back to Nashville on Thursday or so, it's currently in the car working so you could see it in action so to speak if you'd like. You get all the stuff pictured plus fittings and lines on both sides of the filter/regulator. The only thing else you would probably need is the single line going up to the ruel rail. You can have the rail fittings shown too, but not the sensor of course. If you wanted you could have all the fuel line as well, I don't need it.
Not shipping this thing, sorry.
The only catch is that I don't think I have the filler neck, not sure but I think I let it go with my old Spectre tank since I've been using a rubber one.
It's this stuff plus the fittings and regulator https://www.summitracing.com/parts/a...le?prefilter=1 (https://www.summitracing.com/parts/aei-18302/applications/model/chevelle?prefilter=1) Less
https://www.summitracing.com/parts/aei-11540150423150424150425
