View Full Version : Rick/Vapor worx tank leaks
badazz81z28
03-12-2018, 10:54 AM
Good morning,
About a year plus ago I finally filled my gas tank full of gas before I headed out for a deployment. The tank leaked somewhere up top. When you burn gas down it no longer leaked. Based on this I naturally assumed it was probably a bad O-ring in top. Finally got around to swapping the O-ring out with the purchase of a new pump and also swapped out the gasket for the level unit. Filled it up full again for a deployment and to get it tuned...and it leaks. SOB...
Is it possible pressure inside the tank can overcome the o-ring? When I pulled the gas cap off it hissed, but I have a II Much vent. Just looking into possibilities because what ever I do....it Gonna wait 6-8 months till I come back. I have like few miles on this tank and yet according to MCB I bought it 4 years ago! Time is zooming by! Might be better just to get a new tank.
dhutton
03-12-2018, 04:08 PM
My iiMuch vent pukes fuel when the tank is full FWIW. Apparently this is common....
Don
badazz81z28
03-12-2018, 09:32 PM
I wonder if my vent system is blocked, I have never seen that on mine.
dhutton
03-13-2018, 03:10 AM
Something is not right if it is hissing when you remove the cap.
Don
thumper877
03-13-2018, 04:16 AM
I got a email that 11 much is recalling all the vents because of this issue they are sending out replacements free
dhutton
03-13-2018, 04:19 AM
I thought the recall issue was because they were leaking at the assembly joint. Mine pukes out the bronze vent.
https://cdn.shopify.com/s/files/1/0758/8781/files/18E008_18E009_Whammerdyne_R4.pdf?55960287917422870 08&utm_source=Recall+Contact+2&utm_campaign=5fadc6a7bb-EMAIL_CAMPAIGN_2018_02_22&utm_medium=email&utm_term=0_bf2317c6a8-5fadc6a7bb-&mc_cid=5fadc6a7bb&mc_eid=
Don
icemanrd19
03-13-2018, 11:45 AM
Mine did that with my finch dual vent and then stopped. I don't think the vent port on the rick tank is high enough causing gas to get in the line and essentially clogging the line where vapors are unable to escape. I run with about 12 gallons of gas now and don't have a issue
CarlC
03-13-2018, 09:04 PM
Is the tank a fabricated sheet design or stamped steel?
Seems like a leak check is in order. The GM seal, if there are no defects in it or the mounting ring, should not be a problem.
badazz81z28
03-13-2018, 09:22 PM
It’s a fabricated stainless tank.
parsonsj
03-14-2018, 05:32 AM
I don't think the vent port on the rick tank is high enough causing gas to get in the line and essentially clogging the line where vapors are unable to escape.I'm no longer associated with fuel vents, but my past experience with Rick's tanks agrees with this. Is the vent port on the back side of the tank? An inch or so below the top? If so, then you need to treat the bottom of that port as the top of the tank.
badazz81z28
03-14-2018, 09:06 AM
Could that be my problem? Too much pressure? Mine never pukes out the vent but leaks somewhere up top. It does hiss when I take the cap off. My tank vent is on the back about a inch from the top.
icemanrd19
03-14-2018, 10:37 AM
spot on and exactly
icemanrd19
03-14-2018, 10:39 AM
Mine would hiss pretty good after getting on it and mist out of the fuel vent. If yours isnt venting at all it could cause some pressure to build up and find a weak spot. Again by running less than 12 gallons of gas i dont have the issue. I havent tested that theory in awhile though
badazz81z28
03-14-2018, 11:44 AM
I guess I’ll pull the line and see if it’s clear.
JohnUlaszek
01-17-2019, 01:32 PM
Good morning,
If there is ever fuel coming out of a II MUCH brand vent system, you have a problem with the installation. In the case of older Rick's Tanks the issue is related to their venting strategy. There is an internal tube that runs into the tank and depending on how much fuel you put in the tank and the installed angle it can cause that tube to act like a straw trapping pressure in the tank. In the past year Rick's has started adding a second port to the filler next based on discussions we had with them and now suggests the two ports be tied together and t'd into the II MUCH vent system. If you have a II MUCH brand product and you are experiencing this issue, please call the tech line 888-216-6033 and we will be happy to work with you on methods to address this. Again, you should never have fuel bypassing through the vent system and you should never hear a hiss of air pressure when you open the cap. Rick's is aware this can be an issue on some installations and you may want to talk to them about this as well.
carbuff
01-17-2019, 05:16 PM
John,
That is interesting information. I have a pair of the early II Much vent cans and a Ricks / VaporWorks tank in my car. On the road course I occasionally get fuel out the vent tank. I never understood why Rick's put the bung for the vent on the front of the tank instead of the top in the pump area as when I slam on brakes I expect all of that fuel to be thrown at the entry to the vent hose.
I don't suppose you have a picture of where/how they are adding this new port on the filler neck do you? I would have to go look, but I think the neck comes off easily with removal of a rubber hose to the tank. Could be that a port could be added to the neck on my existing tank.
JohnUlaszek
01-17-2019, 05:59 PM
John,
Its not just a port on the front of the tank, there is a tube that extends rearward, upward, and to the side of the tank, so adding a second port location to to the filler next may or may not fix the issue. If it was my car/tank and I didn't want to get into dropping the tank I'd start by plugging existing vent hole, add a port to the filler neck. Keep in mind the port can't be so high that it would cause a trap to form in the line. You want the fuel in the line to return back to the tank via gravity at some point. This would provide you with a single vent location on the filler which is better, but not optimal as it may be difficult to fill the tank -- air is going to have to fight to get out while fuel is coming in. Obviously proceed at your own risk -- this is just an opinion of what might work better for you.
Motobrewmaster
01-18-2019, 04:53 AM
Here is the inside of my Rick's vapor tank (1969 Camaro tank). You can see the tube and how it is routed. I will be plugging this hole and adding two new ones to the front of the tank. Then I will connect the filler neck and those two new vent holes to my II Much vent canister.
https://www.dropbox.com/s/avugqyhrx8e7ag4/IMG_5279.TRIM%20%281%29.m4v?dl=0
John McIntire
01-18-2019, 06:39 AM
Would the vent used with the billet gas cap sold by RideTech be good enough?
It's plumbed exactly as John is describing through the filler neck.
JohnUlaszek
01-18-2019, 06:54 AM
The Ridetech part has two potential issues.
1. Location of port on the neck is likely too hight to use with the VSB, but it could be used with the VSR if the VSR is mounted sufficiently high to allow liquid gasoline to flow back downhill via gravity -- no traps in the line or there will be airflow issues.
2. Filler neck is typically the highest point in the system so it should essentially act as a vapor dome, but it can make it difficult to fill the tank with just the one port as air can't easily escape as fuel enter the tank.
Motobrewmaster
02-16-2019, 03:20 PM
Vent mods to my Rick's tank.
carbuff
02-16-2019, 07:37 PM
For some reason I cannot see that image full size. Did you modify the tank yourself, or did Rick's do this for you?
Motobrewmaster
02-16-2019, 07:56 PM
I modified it myself. Uploaded a better pic so you can see better.
carbuff
02-17-2019, 07:03 AM
Thanx for the better picture. Did Rick's do any venting, or did you weld on the bungs at the 2 corners in the bottom of your picture?
Are you routing exhaust down those areas? Mine is tight there, so it would be a tight fit the way you have run yours.
Motobrewmaster
02-17-2019, 08:29 AM
Here is a better picture so you can see the placement of the bungs. I can't comment on your exhaust routing but it would be up out of the way on my application. That said I have a four link and sway bar in the mess up there too. Exhaust routing sucks for me no matter what I do.
dhutton
02-17-2019, 02:32 PM
Curious why you added the corner vents. I would have thought the filler neck would be adequate along with the vent in the rear of the tank.
Edit: Ok looks like the corners are higher. Makes sense.
Don
badazz81z28
02-17-2019, 02:53 PM
Btw, my leak ended up just being a pin hole in the weld around the pump.
robert worl
06-17-2021, 12:52 PM
Bringing this thread back up because Motobrewmaster has already addressed my question with his tank venting method as shown in the pictures he has posted. How has that venting work out for you Motobrewmaster? I also have a Ricks tank with the vent port in the front of the tank like yours. And I’m considering adding two new vent ports like you did and plugging the supplied port. However I have room to weld my ports in the top of the tank right above where you added yours. I have notched corners in the trunk of my 67 Camaro and my exhaust is far enough out of the way to allow me to vent from the top of the tank and tie the vents together like you have all with -6an hard tube. Then plumb up to a II much VSB vent mounted on top of the DSE shock bulkhead. However running vent tube over to the filler neck like you have done is a little different for me on a 67 without exposed plumbing in the trunk and property draining back to the tank.
So my question is do you think your setup would still work as good if you didn’t have the vent on the filler neck?
also I’m assuming you are using a non vented gas cap with your setup, is that correct?
If anyone else wants to chime in with how they have addressed their tank venting issues that may be helpful as well as I know others have struggled with this whole tank venting issue.
