View Full Version : Cadillac CTS-V Seats in a 1966 Bel Air
olso3904
03-05-2018, 08:02 PM
I scored some first gen CTS-V seats for my '66 Bel Air project and they look like they will fit great after I make some brackets, but I'm not sure what to do for the wiring. I have yet to find a diagram that can tell me the pins that need power in order to operate the motors. I don't care about the seat memory working, so I am wondering if it would be easier to make a relay board and run the motors without the module. Does anyone have a schematic or a diagram with the pinouts for a 2004-2007 CTS-V? Has anyone used these sets before on a build that got them working properly?
On a side note, I removed the side airbags, but can't find a good way to remove/disable the pretensioner, anyone have any ideas on that? 149976
showdog75
03-05-2018, 08:50 PM
I can't answer your questions but I'm looking to use the cts seats as well.
blitzer454
03-06-2018, 03:35 PM
I found the schematics here. (https://www.justanswer.com/classic-cars/7y832-chevy-210-2007-cadillac-cts-seat-wiring.html)
It looks like you can apply battery voltage to the seats and all should work with the exception of the driver's side lumbar support, which seems to be controlled by the memory seat module (MSM), but that can easily be rewired like the passenger side so that it can operate without the MSM.
olso3904
03-07-2018, 09:24 AM
I worked on this for a little bit last night, had the passenger seat working with just 12V and ground, but I could not get the driver's side to do anything. Looking at the schematics, it seems like there RD/WHT wire needs 12v, but it is also looking for Class II voltage in order to turn the module on. It seems like you could bypass the module by giving the switch panel power, like the passenger side, but the physical harness is alot more intertwined than the schematic would suggest and some of the color coding isn't matching what I am seeing. I wonder if an easier solution would be to retrofit a passenger side harness onto the driver side seat.
Do guys installing 2004+ GTO seats have this issue?
blitzer454
03-07-2018, 02:14 PM
Maybe if you provide some pictures of what modules you're working with that would help. Based on the schematics the drivers seat should work as long as you have battery voltage on pin F of the driver's switch and ground on pin C with the exception of the lumbar support which would need to be rewired slightly.
Interceptor5588
03-08-2018, 06:02 AM
GTO seats are super simple -- power and ground and you're done. No heat, no memory = no modules. Those CTS seats will look fantastic, though, worth the effort.
olso3904
03-09-2018, 06:12 AM
I finally figured it out last night and it is more simple than I thought.
I was going to try to bypass the module, but after comparing the layout, I found the passenger seat runs the motor's power through the switch panel, while the drivers seat motors are powered by the module and the driver's switch is just an input. So unless you use a passenger's seat harness on a driver's side, there is no way to bypass the module.
150305
It was easy than I thought power on though, GM used a separate connector on the module for power and ground, so I just had to check continuity on that with the main connector and continuity for the switch on the main connector and it woke up and started working. 150309
I haven't tried to see if lumbar is working, since the module is on, but I would expect that it is now.
The bigger question is how I should connect it to the car. I was thinking of running a dedicated power wire into the interior controlled by a relay off the ignition, so I can can add other power options later. But, even though my factory harness looks like it is in fine shape, an AAW kit is looking more appealing to cleanup the rat's nest that is the factory wiring.
blitzer454
03-09-2018, 02:44 PM
Congratulations, you'll have to post a pic of them in the Bel Air. As far as providing power to the seats, just make sure the circuit is fused from wherever you tap off power from. I would think a 10A fuse would be more than enough. I see it has a butt warmer module too, you'll have to see if you can get that working too :)
130fe
03-09-2018, 02:46 PM
Yeah, with the AAW classic update kit you have so many extra circuits for stuff like that. I wired a set of 4th gen seats with just a fuse inline and it was fine. Relay might be overkill but good to run.
Tincup
03-09-2018, 06:17 PM
I have been running these seats in my Dart for over 5 years. They work like a charm, everything works, lumbar & heat. I had posted up the wiring diagram over at FABO ( For A bodies only) I'll see if I can find it. All you really have to do is power the memory along with the seat 12V.
olso3904
03-13-2018, 06:54 AM
Just finished the driver's side mount last night, which was a little tougher than I was hoping. The floor of the Bel Air is not flat side to side and is canted back about 10 degrees. The CTS seat is also pretty tall with no good options to make shorter without some major structural compromises. I wanted a metal frame structure for the seat mount to bole to that I could later tie into a roll cage, but that would have made the seat too tight up to the steering wheel.
I made flat through floor tab mounts for the front with some backing plates with a nut welded to them for the front. For the rear the CTS uses a horizontal bolt for the outside track and a big flat stamped plate for the inside, but has a reinforced section on the track to use a horizontal bolt. So I cut off the big stamped plate and welded vertical tabs from the floor with gussets going to the driveshaft tunnel and frame tunnel. It's probably overbuilt, but the integrated seatbelt makes me nervous about off-the-shelf mounts.
It took way to long to make the driver's side mount, but I made patterns, so the passenger side should go quick. It was also a good time to cut the trans tunnel for the shifter, since I am swapping the Powerglide for a Muncie.
Should have some pictures soon once I clean up the mounts and make it look a little more polished.
olso3904
03-13-2018, 07:00 AM
Here is a picture from when I was roughing it in. The CTS seat fits a B-Body pretty well as along as you can level out the front and dont mind that it is slightly canted back, the seat has enough adjustment in it to still be able to tilt forward.... if that's what you are into. Getting in and out is fine, will be alot easier with a smaller steering wheel.
150420
I have to find a wiring diagram for my '09 CTSv seats also..... Took over a year to find them!
I cannot wait to have heated and cooled seats! The rear seats need a good bit removed to lower them to fit properly.
Moptop
04-04-2018, 10:20 AM
gnx7, Ive seen pictures for the back seats using plywood to fill in that space and make a mount. That way you dont cut up the seats and the carpet can, hopefully, just lift up a bit to cover the gap.
showdog75
01-05-2020, 08:32 AM
Just curious how the CTS seats worked for you?
Larry Callahan
01-05-2020, 09:00 AM
I am thinking out looking into this for my '55 Bel Air
dhutton
01-05-2020, 09:45 AM
Try to find some Recaro CTS-V seats. They are awesome seats.
Don
jlcustomz
01-07-2020, 09:04 PM
Wife's 2012 CTS premium coupe (non-v model) has the recaro seats, which are heated & vented. Probably same seats as v- models & should be easier to find.
showdog75
05-20-2020, 04:24 AM
Olso hasn't been here in over a year but I wish anyone else with first hand experience wiring these seats up would chime in.
