Ryanater
03-04-2018, 01:06 PM
Hi,
I am having issues with my rear parking bake shoes tearing the rotor hat up. I am running a Baer backing plate, Baer park brake setup (C5/C6 style), and Baer 2 piece rotors. However, I am running C-TEK park brake shoes for what it's worth.
This has happened twice now, and I can't figure it out. The first time was after about 200 miles I pulled the rear rotor off because the park brake no longer worked and found that there was a large lip in the park brake drum where the park brake shoe had dug into the drum/rotor hat. I assumed I had the park brake adjusted too tightly, so I had the drum machined/turned and reinstalled everything and it happened again within a 1,000 miles! In fact it's taken enough material out of the drum that I can completely depress the emergency brake and still spin the rear wheels with no resistance.
I have no idea what is causing this. I don't remember driving with the emergency brake on, but even if I did, wouldn't it do more damage to the pad rather than the parking brake drum?
The brakes are installed on a 12 bolt rear that has axle ends made to accept the large Ford tapered bearings. I also autocross the car frequently, but I don't see how any of that would play a part in the park brake issue.
Any ideas would be greatly appreciated.
Link to brake kit I am running (except I am using a Brembo Caliper with a custom bracket)
http://baer.com/14-Rear-Pro-Plus-Brake-System-with-Park-Brake-4302266.html
Link to park brake shoes I am using.
https://www.summitracing.com/parts/ceb-110-07840/overview/year/2011/make/chevrolet/model/corvette
