jasonz28camaro
02-28-2018, 10:29 PM
Selling the 9" my car came with when I porchased it last year. I know little about the rear but I'll share what I know.
The 9" is shortened a little over the stock camaro length but still has Ford bolt pattern axels in it. The overall length is 58.5". It currently has GM bolt pattern wheels and uses 1.25" wheel adapters (not included but can be) making the overall length 61". You could swap axels to GM bolt pattern units and get it to the narrowed overall length of 58.5" if you wish to do so.
Rear is a posi unit and gears are somewhere in the neighborhood of 3:00 to 3:50. 2500 RPMs going 70 with a 700r4. Only guessing the ratio so it could be off. 28 spline axels, 11" disk brakes, drilled and slotted rotors with ebrake, unknown make or model.
Also selling the multi leaf springs and traction bars the car came with, everything in the photos minuse the front leaf spring brackets and wheel adapters.
PS axle seal has a small seep.
Asking $500 picked up in Houston. Will not separate parts, all or nothing at this price.
14982514982614982714982814982914983014983114983214 9833
