CarlC
02-26-2018, 08:56 PM
https://i.hmjimg.com/images/2018/02/26/20180225_134418.md.jpg (https://www.hostmyjunk.com/image/X0BEt)
https://i.hmjimg.com/images/2018/02/26/20180226_1122431.md.jpg (https://www.hostmyjunk.com/image/X0Hsc)
https://www.vaporworx.com/product/bosch-map-sensor-mounting-bracket/
Looking for a remote mounting bracket for the modern Bosch sensors used in GM LS and LT engines? VaporWorx has the solution.
Compact and very rugged, this kit comes with everything needed to mount your sensor, including the electrical plug and components.
This bracket is an ideal solution for remote mounting the MAP sensor and for dynamometer operators looking for a simple to use and adapt system.
Features of the sensor bracket include:
-6061 hard anodized aluminum.
-Three pin plug, terminals, and seals.
-Brass barb fitting for 1/8” hose x 1/8” – NPT thread.
-Sufficient clearance to use AN fittings for vacuum line.
-MAP sensor hold-down screw.
-Stainless steel mounting screws.
-Four feet of vacuum hose.
MAP sensor is not included
