wyattroa
02-14-2018, 06:01 PM
Should my upper control arms look like this? Each one has the control arm offset to the right hand side where it attaches to the ears on the rear end. The driver side comes in perfect since the control arm is in line with the inside of the car. But on the passenger side its causing the joint to be angled from the same offset as the drive side. The control arm is moved to the outside versus the inside. The one on the passenger side is not flipped and is installed correctly.
149261149260
149261149260
