ryeguy2006a
02-14-2018, 05:24 AM
Hi there,
I picked these up a while ago and realized that I won't be needing them. They are a complete set of 8 brand new High Flow Fuel injectors Number HFP-IN42LB. They are rated at 42lb @ 43psi, and somewhere around 50-52 lbs @ 58psi. I believe they will support modded cars around the 550 HP range. They are also a direct replacement for the LS1 injectors. I will sell for $100 shipped to the Lower 48 states.
I was asked a question by another member here and these injectors don't have a part number on them which means they aren't true Bosch injectors. They are a knock off, which is the reason for the price drop. I just don't need them and could use the money for bodywork supplies.
https://static1.pt-content.com/images/pt/2018/01/38799760215_57dedef819_b-1.jpg
Ryan
Ryan
