1976CamaroGuy
02-02-2018, 05:01 AM
$165 shipped a set to lower 48 - can ship to Canada and other places for the additional cost of shipping
Fits 1970-1981 Camaro or Firebird
No Speakers are included, these are raw panels ready for you to finish and add your own speakers
Comes with both kick panels, pinch weld and instructions, will be finished in a smooth white gel coat primer and it’s up to the end user to finesse the fit and cover in vinyl or paint.
Some prep will be need if painting as you would any fiberglass part.
If you decide on vinyl and want to match the factory door panel grain you are going to want to use sierra grain vinyl on later cars and madrid grain vinyl on early cars.
Some trimming required to get a tight fit to your car
Parking brake can be retained, you may have to shim it out or bend it a bit to gain clearances over the speaker grille.
Holds a component set with a tweeter and 6.5” speaker and up to a 7” diameter grille.
Will work with Factory AC but you need to remove the flapper actuator in the passenger kick panel and cap off the vacuum line.
If you have factory non AC you will need to get creative with the fresh air vents pull knobs, in most cases you will lose them unless your able to come up with something. I am not familiar with those systems.
If you have Vintage Air, no problem that's what I put on my personal 71 Camaro and I provide instructions on how to mod the set-up to work with these kick panels.
To protect the rear of your speakers you just need to purchase a set of Metra 81-6900 Speaker baffles, they fit perfectly inside the opening and give the speaker something to play into, while protecting it from the elements. You can get these on eBay from various sellers for around $10-12 shipped.
