View Full Version : 1967 camaro pro touring project. Complete, minus engine and trans, 100 pics
modena35
02-01-2018, 10:25 AM
148626148627148628148630148629SEE ON EBAY http://r.ebay.com/YKUgsO (http://r.ebay.com/YKUgsO)
1967 CAMARO PRO TOURING PERFECT SIMPLE PROJECT. FORGELINE, DSE, WILWOOD, LS
YOU ARE BIDDING ON A COMPLETE, RUST FREE, FRAME-OFF RESTORED, PRO-TOURING 1967 CAMARO (MINUS DRIVETRAIN) AND $30,000 IN HIGH END AFTERMARKET PARTS.
This car has had a complete frame off restoration. There is not a spot of rust on this entire car as you will see in all the pictures. It is the perfect Pro-Touring project car because every part has already been purchased and is included. All that remains to be done is pick your choice of motor and trans, strip and paint it, and re-assemble. The car currently has the front and rear suspension, wheels and tires installed so that it is easily transportable (as shown in the first few pictures). Every stainless bolt, screw, and wire has been labeled and is very easily re-assembled after your body and paintwork. The interior is a full brand new leather sport package including all new door panels, new carpeting, and Dynamat. There are all high quality carbon fiber body parts included that will make your pro-touring car stand out including: 2” cowl hood, truck lid with rear spoiler, header, upper valance, cowl, front spoiler, center filler panel, and all interior gages are carbon fiber to match. The car is currently stripped down (as pictured) to its shell, completely painted in metallic blue, with the suspension and wheels installed so that it is easily transportable. ALL PICTURES ARE AS THE CAR SITS NOW UNLESS MARKED OTHERWISE. I HIGHLY ENCOURAGE ANYONE TO COME SEE THE CAR PRIOR TO BIDDING. CAR IS LOCATED IN ROYAL OAK, MICHIGAN (48067). I ALSO CAN TAKE AND SEND ANY PICTURES YOU REQUEST TO YOUR EMAIL OR TEXT.
THE FOLLOWING IS INCLUDED WITH THE CAR:
Detroit Speed complete Mini-Tub installed
Detroit Speed Smooth firewall installed
Dynamat Sound deadener installed
Forgeline 3 piece wheels/rims 19/8 front 19/13 rear $7000
Anvil Auto Carbon Fiber: 2” cowl hood, truck lid with spoiler, header, upper valance, cowl, front spoiler, center filler panel $4000
Nitto 345 drag radials rear. Nexen fronts $1200
Perfect Launch rear end with 4 link suspension, Dual coil over QA1 shocks, and sub frame connectors $3500
Wilwood front 6 piston, crossed drilled rotors, with aluminum Superlite hub $1900
Wilwood rear 4 piston cross drilled rotors with rear parking brake $1600
Tubed A-arms with 2” drop spindles. $750
QA1 R series dual coilovers with springs (qty 4) $1700
Be Cool aluminum radiator polished with dual polished finish cooling fans $1500
Anvil Auto carbon fiber dash panel with Auto Meter carbon fiber gauges $1100
Ididit steering wheel column with billet aluminum and leather steering wheel. $900
Solid polished aluminum Marquez LED tail lights $900
Stainless steel gas tank $350
Complete new leather interior including door panels, headliner, and sport seats with Simpson harness lap belts $2000
Complete set of stainless brake lines,
All stainless bolts and hardware
All stainless fuel lines
HID headlight conversion with wiring harness
1 slow 97
02-02-2018, 01:37 PM
Please reach out to me, sent you a PM. Thanks!
redbull396
02-25-2018, 05:39 PM
Did this car sell?
1 slow 97
02-26-2018, 08:08 PM
It did.
Stan
04-17-2018, 06:05 PM
Is car still available 813 226 7402
Wildcobra
04-17-2018, 09:33 PM
Wow that was a quick sale :(
