View Full Version : What prop valve do I have here?
ULTM8Z
01-28-2018, 10:52 AM
Before my dad passed away, he was going to convert his rear drum '71 Camaro to rear disc so he bought a bunch of parts for the conversion, including a proportioning valve. My strong suspicion is it's a 4 wheel disc valve from a 4-wheel disc Trans Am/Firebird. It's never been used and has been in storage for the last 6-7 years or so.
With my brake woes going on, I was thinking about putting on this new proportioning valve to rule out the prop valve as the issue.
But I'm not 100% certain, so I figured I'd ask here to see if anyone knew...
It's a brass body valve identical in appearance to this one, but it has some markings stamped on the side that I can't seem to locate online...
HJ 9 349 9419
minendrews68
01-28-2018, 11:28 AM
To me it looks like a GM valve. Pretty common, so you shouldn't have any problems. Hopefully someone else will respond.
ULTM8Z
01-28-2018, 11:30 AM
Yeah. The main question is it a 4 wheel disc valve...
Zspoiler
01-28-2018, 03:13 PM
You want one from a 1979-81 Firebird .part number 1257189. That is what I use on my 1979 Z-28 RS Camaro with 4 wheel Baer Brakes
