View Full Version : 1969 Camaro SS Front wheels and tire?
Z28-PLT
11-28-2005, 08:21 PM
I am about to undertake the Pro-touring wheel mod endeavour! I was thinking with going standard fit 17x7 and 17x8 ARE TTII's but I just saw a 69 SS with 17x8's front and 17x11's rear!!! I am now hoping to take this route. However, which method do I take:
17x8's front what size/backspace?
Tires will probably be a Sumitomo 255/40ZR17
17X11 rear what size/backspace?
Tires will probably be a Sumitomo 315/35ZR17
***I am aware of the need to mini-tub. I am hoping to buy the DSE kit for this mod. Any word on installation costs for a kit like this. What kinda labor would be involved and costs associated besides parts? Can I keep stock drums in the interim? and replace to disks later? Fronts should work without mods right? Any assistance is greatly appreciated-thanks.
-Rick
11-28-2005, 11:15 PM
Hi Rick,
Your looking at 35-50 hours of labor, a good amount of welding and fabrication. most shops are in the $65-75 an hour range.
Look for deals like group purchases for the DSE kits, they run $1300 and you will have to supply the shocks and cut out material.
I suggest measuring your car for rims after the rear is mocked up.
SatisTraction
11-29-2005, 10:34 AM
rick
where ar you located?
Z28-PLT
11-29-2005, 07:42 PM
Thanx fellas. I have found that an Air Ride technologies 4 link rear setup will work best for the rear application. I will go with installing this and removing the leaf springs altogether. HOwever, what will be the 17x11 wheel offset with this and going with a 3" DSE minitubs?
BTW-I located in Alamogordo, New Mexico (Holloman Air Force base)
Z28-PLT
11-29-2005, 07:47 PM
I have narrowed down the rear approach for my 69 SS. However, what is the largest size offset I can go on installing a set of ARE TTII's for the front? I have heard of some guys going to a 17x8 BS???? and 245/45ZR17 tire? Could I even possibly fit a 17x9 and 255/40ZR17 on the fronts? I don't know what backspace will work. Car is fully stock with intention of eventually going to an air bag front suspension.
Ralph LoGrasso
11-29-2005, 08:27 PM
Threads merged.
17x8 and a 245 is the standard size most people run. I'm pretty sure the desired backspacing is 4.5" or 5", but I'm sure someone will confirm. Also, do a search as this topic is covered atleast once a week. Keep in mind, every car is different, so it's always best to measure your specific car to be certain on fitment.
A 17x9 will fit on the front if you use steering stops, and remove the inner fenders. You may still have to deal with some slight rubbing. You can stuff a 255 on the 17x8, though. If you want to step up to a 275, then go with the 17x9, if all you want is a 255, then run it on 17x8.
Z28-PLT
11-29-2005, 08:45 PM
Ralph L,
What are steering stops? Never heard of these, soo I am kinda lost on this detail. Also, if I got with a 17x9 wheel on a 275x40 tire will the asthetics reflect much diffrent that a 17x8 and 255x40 tire?
What inch difference is between 255mm and 275mm in terms of tire size? Do this equate to about 1 inch difference?
Ralph LoGrasso
11-29-2005, 08:51 PM
Steering stops are used to restrict turning radius. They basically consist of a bolt and jam nut, placed in the spindle.
The asthetics aren't going to be that great, but generally a wider contact patch will handle better. Also, since you're going to be mini-tubbing a 275 would offer a better balance between the front and rear tires. It's your preference, though.
255mm = 10.03"
275mm = 10.82"
This is just standard conversions, though. Different tire manufacturers will vary slightly in size.
11-29-2005, 11:36 PM
Steering stops are used to restrict turning radius. They basically consist of a bolt and jam nut, placed in the spindle. in the case of a 69 Camaro its a plate welded or riveted to the lower a arm. It contacts a spot on the spindle... you can reduce by welding an extra piece on top of the existing one. there are stops in the box but I can't/wont go there.... :drive2:
Ralph LoGrasso
11-30-2005, 02:26 PM
Thanks for the clarification. I haven't actually done the stops yet on my '68, as I'm sure you can tell. :p
