View Full Version : ..which size bore master cylinderi really need
De-noz
01-17-2018, 08:13 AM
Guys, i have a to hard brake pedal feeling in my 65 Olds 442 with a 1" master and disc/drum
( pushrod bolt to upper hole)
This combination works until i switch from power to manual... always read that with power brakes you need 1 1/8 and with manual 1 "
Sooo it´s seems i´m a exception, question is now...which size?
Must i goo to a 15/16“ master and hope everything will be okay or better go to 7/8“ and be safe ?
thanks from germany
65 drop top
01-17-2018, 11:53 AM
It really depends on your calipers piston area and pedal ratio. Which calipers are you using? I'd guess pedal ratio is 6:1? Most likely though a 7/8" is going to be what you need.
De-noz
01-18-2018, 01:02 AM
What i know is, the front Disk (10.75") & calipers are from the 67-72 cars...i assume stock size is 2.75" (one piston)
About the piston ratio: really don´t know, never measure it--- I only bolted the rod to upper hole....
Let me know if must measure the ratio.
andrewb70
01-19-2018, 08:08 AM
Why not go back to power brakes?
De-noz
01-21-2018, 08:26 AM
no space for a booster.
think i try a 7/8" bore MC and see what happens, may some one know a low cost 7/8" MC with 1/2"-20 & 9/16 ????
andrewb70
01-21-2018, 08:45 AM
I don't remember the port size, but I'm using a 7/8" bore MC from a 1995 Dodge Sprint. It's aluminum and has a plastic reservoir. The bolt pattern is not quite right, but it's easy to elongate the holes. I think I paid $65 for it. Works awesome.
Skip Fix
01-21-2018, 09:40 AM
Most of the stock F and A body manual disc/drum cars did use a 1".
I think there is also a smaller than 1" aluminum manual S-10 MC.
TheParker
01-26-2018, 06:56 AM
What dowel did you use and how do you keep it in place?
andrewb70
01-26-2018, 10:23 AM
By "dowel" I assume you are referring to the pushrod? The MC has a deep pocket for the pushrod and I reused the push rod that came with the 79 Malibu MC that I had before that.
