KiwiStarChief
12-31-2017, 04:11 PM
I have an issue with my 1957 Pontiac Star Chief. When I got it, it had dearched rear springs, 2" lowering blocks, and load leveler rear shocks (with a coil spring).
As it was riding a bit harsh, I replaced both front and rear shocks (front suspension is a front clip from an '78 Malibu). Front worked out OK, but the rear shocks were replaced with Gabriel 82156 Heavy Duty Classic gas units. These have an extended length of 20.23", and a collapsed length of 12.37". Unfortunately these shocks lowered the car by a further inch & a half, which was too low. I have now adjusted the ride height by replacing the blocks with smaller ones, and the height is back to where it was.
My issue is that when hitting a bump in the road, the pinion head is hitting the bump stop with a thump. I tried shortening the stop by 1", but it is still hitting, so I assume the shocks are not as hard as the load levelers, allowing this to happen.
Should I just remove the pinion bump stop, or are the shocks the wrong working length for my lowered car? I also note that there are no rear axle bump stops fitted, so a previous owner has removed them for some reason.
I would greatly appreciate any advice or suggestions you may have to resolve this problem.
