View Full Version : JAKEFAB billet lower control arms for Crown Vic, or frame swapped projects.
redmist
12-15-2017, 12:55 PM
https://jakefab.com/products/billet-lower-control-arm-kit-crown-vic-marauder-pre-sale
PRE-SALE Shipping begins in February 2018 or sooner!
Designed to fit the 1998 and up panther chassis vehicles, these lower control arm kits will vastly improve the handling of your vehicle. The large I beam design is made from billet machined 6061-T6 aluminum, and then Mil-spec hard coat anodized for the ultimate in corrosion resistance. The replacement grade-8 hardware reduces the slop in the factory frame through hole mounting points. Energy Suspension Poly Graphite bushings are standard at each end. Semi-recessed grease zerks fittings are pressed into the lower portion of the arms for service intervals. Machined logo cam be place inside or out depending on aesthetics.
CNC Machined Billet 6061-T6 Construction
Type III Class 1 Mil-spec hard coat anodized
Energy Suspension poly graphite bushings
Fits 1998-2011 panther chassis Crown Vic/Marauder
Pressed in semi-protected grease zerks for mantainance
Grade-8 bolts, poly lock nuts, washers included
Reduces slop in factory frame through holes
Made in the USA, product of the great State of Idaho
